Old 25-05-2009, 12:46 AM   #1 (permalink)
Default hd movies and tv programe
hi all ,
please help me to solv dis prob !
m not able to play hd movi on my desktop.
my pc cofig is :
p4 2.66 gransdale
1256 mb ram
64 mb n vidia ge force4 mx 4000 (AGP)
what can b the problem ,as i don't hav onboard graphics.
s ther is prob with graphic card . i am trying hd movi files with GOM player and it is very slow. movies r of 720 P....
please suggest some solutionsss ! ???
suresh.nitraipur is offline
Old 25-05-2009, 01:22 AM   #2 (permalink)
Default Re: hd movies and tv programe
i hav installed klcodec485f codec pack also..
it does not wrk....
Old 25-05-2009, 01:41 AM   #3 (permalink)
I am sorry to tell you but i think thats because you have a prehistoric graphics processor
threeonethree is offline
Old 25-05-2009, 08:38 AM   #4 (permalink)
Tech addict
surinder's Avatar
Although you can escape with upgrading graphic card only but for the long run AGP card nowadays not advisable in that case you have to upgrade your motherboard as well for the sake of a PCI-e card you can go for any G31 chipset based mobo + Palit GF9500GT 256MB DDR3 in total 6.5K. Possessor and RAM upgrades are also considerable for the sake of total system performance improvement.
surinder is offline
Old 25-05-2009, 12:22 PM   #5 (permalink)
I M A *STAR*
saqib_khan's Avatar
suresh.nitraipur , with that configuration, u can't play HD . U should upgrade if u want to play HD stuff.
Blogging at:
Technostarry
saqib_khan is offline
Old 01-06-2009, 11:05 PM   #6 (permalink)
@ all thanks ...for input..
good news for me is i am able to play hd movi now with m player !
