Guys,
I'm totally frustrated due to this overheating issue. I have Uploaded the screenshot so please take a keen look at it. However the bios is showing very low temperature and i dont get any improper shutdowns as well. Can it b due to faulty Sensors if not please mention some technique to Lower the temperature
I spit Rainbows.
I use a local odessey smps. I'm thinking of gettin a new one with ati 4770. Please suggest something cheaper than vx 450 ,i know nothing beats it but i'm tight on budget.
Waitin for a quick reply.
^^ Corsair cx400- 3.5k
After changing the power supply, run the system on default clocks and run orthos blend test 5-6 hours to make sure your old psu didn't damage the system.
So should i consider these temp. fine. I'll be getting a gfx card soon so psu will be changed. What do u say about cm 460w with ATi 4770 as i wont be ocing my pc.
