Old 22-05-2009, 04:31 PM   #1 (permalink)
The Incredible's Avatar
Default 2GB PenDrv showing only 49MB
Recently from an old Digit DVD I turned my PD into a bootable device with DSL in it. The problem is when I formatted it, it ate up my PDs memory and my computer is only showing disk space of 49 MB. How could I get the lost memory back ?
The Incredible is offline
Old 22-05-2009, 04:33 PM   #2 (permalink)
Default Re: 2GB PenDrv showing only 49MB
Did you create more than one partition on the pen drive?
ThinkFree is offline
Old 22-05-2009, 04:40 PM   #3 (permalink)
Nope I didn't. Does that matters ?
Old 22-05-2009, 04:54 PM   #4 (permalink)
The Sorcerer's Avatar
Either its a defective or its a duplicate/substandard flash drive.
Hardware BBQ
The Sorcerer is online now
Old 22-05-2009, 05:00 PM   #5 (permalink)
Kingston Data Traveller 2.0 GB
Are you sure ?
I had formatted it many times. It's first time this happened. Isn't there a S/W solution available ?? Isn't some recovery s/w capable to help me ?
Old 22-05-2009, 05:23 PM   #6 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Probably Windows is only able to see the FAT32 partition and not the partition made by DSL, hence it only shows 49MB of free space. Plug in the drive and take a look at it in the Disk Management console (diskmgmt.msc). Most probably you'll see an unrecognized partition on it. Delete it and also delete the FAT32 partition. Now do a full format of the drive.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 23-05-2009, 12:13 PM   #7 (permalink)
How much capacity do you see in linux? See in disk management in windows or use fdisk -l in linux. Other partition may not have been formatted.
Old 02-06-2009, 07:20 PM   #8 (permalink)
i don't use linux. i had a bootable dvd with which i created a bootable usb. and the i formatted it. and the linux desktop was larger than my screen so i was unable to do much. anyways tell me solution in windows pls.
Old 02-06-2009, 07:23 PM   #9 (permalink)
as a matter fact
i installed Damn Small Linux (size 50mb). so windows is only able to see that partition.
and that's FAT32 only as i formatted on windows vista
any more clues what happened ?
though i haven't done the DMC thing. i will try it today...
Old 02-06-2009, 07:31 PM   #10 (permalink)
It was there in my last post.
Old 02-06-2009, 07:38 PM   #11 (permalink)
Under what section of DMC ?
USB or what ?
What special shall i look for ?
Old 04-06-2009, 07:10 PM   #12 (permalink)
^It should be at the same place where your hard disk partitions are shown.
Old 05-06-2009, 11:15 PM   #13 (permalink)
ashamed i shud've lukd b4 askling dose question of DMC.
problem solved.
thnx a zillion!
