Old 22-05-2009, 09:21 AM   #1 (permalink)
Default Low Write Speeds with Sata Samsung Dvd Writer
Hi,
I purchased a Sata Dvd Writer - Samsung SH-S223F around 2months ago.
Used it a to burn a few dvd's/cd's and all was fine.
but just the day b4 wen i used it to write a dvd at 8x speed and another at 16x
speed both the times it took almost an hour to burn the dvd.
The writing took nearly 45min and the verifying to another 10-15mins.
the dvd is fine, no errors, nothing. but then, any idea why the sudden drop in
speed of burning a Dvd.....
It is running on its latest firmware- SB03.
Is it a problem cuz of DMA or something. can i check it.
wen i checked with nero tools t shows DMA 5 Active on the drive.
Please advice me on the same
Thanks
cloydmello is offline
Old 22-05-2009, 09:35 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Low Write Speeds with Sata Samsung Dvd Writer
did you check with any other burning software?
desiibond is offline
Old 22-05-2009, 10:13 AM   #3 (permalink)
No i have not....
Which other software do u recommend......??
Thanks
Old 22-05-2009, 10:25 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
ImgBurn
CDBurner XP Pro
Old 22-05-2009, 10:36 AM   #5 (permalink)
Thanks buddy...
Will have a try usiing these softwares....
Old 25-05-2009, 05:31 PM   #6 (permalink)
the speed is still 1.8x wen i use imageburn....
Is it a Firmware prob
I checked the DMA Settings in the Device manager and also the Bios
It is active and running at DMA5
Any hlp as in what can i do...
Thanks
Old 26-05-2009, 09:12 AM   #7 (permalink)
15.0 GHz
VarDOS's Avatar
yes its frimware prob, get re patch the current frimware with the latest one
check here
http://www.cdrinfo.com/Sections/Firm...x?DriveId=1598
VarDOS is offline
Old 27-05-2009, 09:07 AM   #8 (permalink)
ITS WORKING....yipppieee.....
VARAD, Thanks a Lot buddy, ur idea about the Firmware made me revert the drive back to the SB02 F/W and its working absoluetely fine now.... writing the drive for me at the deserved speed....yeaahhhh.......
Thanks
Old 28-05-2009, 10:44 AM   #9 (permalink)
15.0 GHz
VarDOS's Avatar
its my pleasure
VarDOS is offline
