Hi,
I created this thread last night, but for some reason, I cannot see it here. So am creating it again.
On my motherboard is a 12V (4 PIN) ATX power supply port. What is this used for. It is the one right above the primary PCI.E expansion slot. Am I supposed to insert a 4 PIN Molex from my power supply into this, or 'can' it supply power to the graphics card. Basically is it a power input source or power output source. Does it have to be connected. The link for the mother board is:
http://www.msi.com/uploads/prod_7f19...3a030ee313.jpg
It is the white four pin connector right above the Blue PCI.E slot.
thanks an lot for the help,
asigh
