Old 20-05-2009, 11:11 PM   #1 (permalink)
ay_aceoo7's Avatar
Default help plz....
hey other's cant see ma created server in CS 1.6....my modem is Bsnl huawei mt841.....wat is the actual problem?
ay_aceoo7 is offline
Old 20-05-2009, 11:37 PM   #2 (permalink)
Point Blanc
Default Re: help plz....
are u talking over internet or local LAN, if internet bcoz u do not have a static IP.
there are few steps to be followed to get it correct if you do not have static IP.
You must be playing over IGZones or somewhere, check in their forums and guides for the solution.
acewin is offline
Old 21-05-2009, 12:21 AM   #3 (permalink)
uchiha_madara's Avatar
set pppoe settings in your modem,GIYF
"Any sufficiently advanced technology is indistinguishable from magic"
Clark's Law
uchiha_madara is offline
