Old 20-05-2009, 08:29 PM   #1 (permalink)
BSD init pwns System V
hellknight's Avatar
Default New Central Processing Unit for 25k
Hi guys
I want to upgrade from my old AMD 4400+ X2 system to a new one. I've made the following configuration
1 AMD Phenom 720 BE - 8100
2 Jetway HA 07 Ultra - 6000
3 4 GB DDR2 800 MHz RAM - 2500
4 Palit GTX 260 - 11300
Total - 28k
I will be selling my Old processor, mobo and 2 GB RAM and hope that it would fetch me around 3-4k. I already have a Cooler Master 400W PSU.. but i think that i need to upgrade to a new one.. Already have WD 250 GB SATA II and Sony DRU 835 A.
So, suggestions are welcome.. please review it
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 20-05-2009, 08:52 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: New Central Processing Unit for 25k
gr8 choices
consider gigabyte 790G/FX mobos too.
and yup, better PSU is needed. VX 450 will do proper justice.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 20-05-2009, 08:53 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
how about GA-MA790GP-DS4H for motherboard. It's a bit costly but look at the features:
http://www.gigabyte.in/Products/Moth...ProductID=2887
desiibond is offline
Old 20-05-2009, 09:29 PM   #4 (permalink)
hellknight's Avatar
Actually i want to go for AMD 790 G chipset based board... don't need crossfire as GTX 260 is enough for a 19" Viewsonic VA 1912 WB LCD.. I would be very pleased if you guys could recommend me a single GFX slot based mobo under 6000 and on the same chipset..
Old 20-05-2009, 09:31 PM   #5 (permalink)
hellknight's Avatar
The only difference between the Jetway and Gigabyte product is that it Gigabyte has both slots running at 16x.. and nothing else. am I right?
Old 20-05-2009, 09:38 PM   #6 (permalink)
dOm1naTOr's Avatar
overclocking, stability and capacitor quality.
G3: XPS M1530 |
FZ 16.
Old 20-05-2009, 09:52 PM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
better thermal rating
better heat sinks
silent heat pipe
Inside 6k, you can go for the same board that I bought (5.1k) but it doesn't have MA78GM-US2H
Old 20-05-2009, 10:04 PM   #8 (permalink)
dOm1naTOr's Avatar
but its micro ATX
G3: XPS M1530 |
FZ 16.
Old 20-05-2009, 10:35 PM   #9 (permalink)
Tux Fan
shaunak's Avatar
The D series brings all solid capacitors to the board, improving overclockability. I would recomend the MA78GM-S2HP/DS2HP.
I can tell you first hand that Gigabyte's aftersales is really good.
Most boards under 6K are MicroATX today.
You could look for the biostar 790 board. It also retails for 6K but is really hard to find.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 21-05-2009, 05:59 AM   #10 (permalink)
hellknight's Avatar
The Jetway HA 07 ultra also has solid state capacitors.. don't care about temperature as the room temperature hardly goes above 30 degrees here ... Is the Biostar one ATX.. or MicroATX.. ?
Old 21-05-2009, 07:29 AM   #11 (permalink)
Tux Fan
shaunak's Avatar
ATX I believe.
* TA790GX 128M
If you are buying a biostar, make sure your dealer knows where the service center is, or he can arrange for warranty for your. Their India presence seems to be poor.
Cheers
Shaunak
shaunak is offline
Old 21-05-2009, 09:26 AM   #12 (permalink)
Bond, Desi Bond!
desiibond's Avatar
http://www.jetway.com.tw/jw/motherbo...ame=HA07-Ultra
I was looking at this board's features and damn, it looks great
1) Heat Pipe
2) 790GX Chipset and AMD™ SB750 Chipset
3) AMD OverDrive(AOD)
4) CrossFireX
5) 128MB side port memory
Also by looking at the cooling applied on the mobo and solid capacitors, this mobo certainly looks good.
Old 21-05-2009, 10:14 AM   #13 (permalink)
hellknight's Avatar
Yeah.. this motherboard is damn hot in the features department.. the only regret is that crossfire runs in 8x per slot.. but anyways.. i won't be implementing crossfire anytime soon.. The board is a hot looker.. and its performance is also great..
Check this out
Old 21-05-2009, 05:17 PM   #14 (permalink)
dOm1naTOr's Avatar
wats it price?
G3: XPS M1530 |
FZ 16.
Old 21-05-2009, 05:23 PM   #15 (permalink)
j1n M@tt's Avatar
Jetway HA 07 is not as bad as u guys think, it hav got some gud admires in the global market.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 21-05-2009, 06:13 PM   #16 (permalink)
Point Blanc
have a few question
what is side-port memory.
my mobo has something called UMA ultra buffer. What is UMA ultra buffer memory.
how can I check how much of my RAM is acting as shared memory to GPU or increase it.
my mobo has ati 200 chipset and I am talking about the onboard gfx.
an jin, how good is jetway boar for long run if I want to keep my config running for more than 2 years.
acewin is offline
Old 21-05-2009, 06:47 PM   #17 (permalink)
dOm1naTOr's Avatar
solid caps ensures longer life, and that board looks solid.
G3: XPS M1530 |
FZ 16.
Old 23-05-2009, 04:31 PM   #18 (permalink)
laborare est orare
Cilus's Avatar
My suggestion is also for Biostar TA790GX+128M board. I'm currently using that one and the board is really good. Its a good overclocking board too. I overclocked my Phenom II 940 to up to 3.7 GHz without any problem. Price wise it is the best value for money board. Price is around 5.2kto 5.4k. But if u r lucky u can get it at 5k
Cilus is offline
Old 23-05-2009, 04:50 PM   #19 (permalink)
dOm1naTOr's Avatar
Biostar TA790GXB A2+ is almost same w/o the sideport memory n one PCIE 16x, is about 4.2k. Got solid caps near CPU socket.
G3: XPS M1530 |
FZ 16.
Old 23-05-2009, 05:17 PM   #20 (permalink)
j1n M@tt's Avatar
the availability of TA790GXB A2+ is very low in India....except in some online sites like Lynx.
j1n M@tt is offline
Old 23-05-2009, 09:43 PM   #21 (permalink)
hellknight's Avatar
But does the biostat one supports enabling the fourth core in the 720BE CPU? I'm also going to buy the Asus silent knight CPU cooler. So jetway is recommended for such a job will biostar support it ?
Old 23-05-2009, 10:08 PM   #22 (permalink)
dOm1naTOr's Avatar
actually its the feature of MCP 790GX/FX. all mobos of with this chipset shud support, but some earlier released ones might need some bios updates in worst cases.
enabling frequency calibration enables the core.
G3: XPS M1530 |
FZ 16.
Old 24-05-2009, 02:17 PM   #23 (permalink)
laborare est orare
Cilus's Avatar
Actually any 790G chipset based board with Advance Clock Calibration function enabled, supports enabling of the 4th core of the Phenom II X3 processors. But it also depends upon ur processors. Some batch of the Phenom II X3s are having a not fully damaged 4th core. Only they can be enabled. They may have some faulty register or some portions of the Cache disabled, but still in a workable condition. If the 4th core is highly damaged, then it may not be possible to enable it.
Cilus is offline
Old 24-05-2009, 02:33 PM   #24 (permalink)
damnbadman666
damngoodman999's Avatar
PALIT HD 4870 sonic 1GB DDR5 replace with GTX 260
its now avail for 12.3 k
damngoodman999 is offline
- by Anorion
- by ax3
