Old 19-05-2009, 02:02 AM   #1 (permalink)
Super Moderator
asingh's Avatar
Default HD4890 on a Corsair TX650
Hi,
I ordered a HD4890 and a Corsair TX650. (And various other stuff for my new build)
The problem I am worried about:
The HD4890 needs 2 -- 6 PIN PCI Express Power Connectors. The websites say that the TX650 does not have 6 pin PCI connectors, only 2 --- 8 Pin ones. Will I need to hook up the card, using Molex converters (Molex to 6 pin converter cable). Are these converter cables available at Nehru Place, New Delhi.
It will be kind of irritating to find out that I ordered 50K worth of high end computer parts..and did not think about the cables...!
Link for TX650
thanks for the help..!
Anil
asingh is offline
Old 19-05-2009, 02:09 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: HD4890 on a Corsair TX650
it can handle it easily evenif u use a converter cable. Also make sure u connect 2 molex pins into the converter.
http://www.tenthousandpercent.com/fi...2molex_118.jpg
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 19-05-2009, 07:57 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
@ asigh - you will get Molex to 6 pin converter cable with the gfx card. So don't woory. BTW, these two 6 pin pci-e power connector will consume 4 molex connectors of your psu
BTW, if you are running out of molex connectors you can always buy molex y-cable. With this you can run two molex devices using a single molex connector. So don't worry.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 19-05-2009, 08:04 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Hey..thanks..to all..for such prompt replies...
I am not worried about the TX650 able to handle the card..I am sure it can..! Was just worried that...will I get the converter (6PIN)...with the powersupply..since it does not have 6 pin connectivity.
The Powercolor 4890 card does not come with a converter..meaning..does not ship with it..as standard accessories...
asingh is offline
