Old 14-05-2009, 12:24 PM   #1 (permalink)
Good Boy
george101's Avatar
Exclamation Ony 3Gb on Vista 64bit!!!
my config is C2D 8400, 2x2gb 800MHz ram, Asus P5Q-Pro, 500gb HDD, XFX 8600Gt,...
the problem is that my vista ultimate 64bit is showing only 3gb, i even tried Win7 64bit, but still same. there is something called "Memory Re-mapping" in the bios. tried enabling and disabling it, but no use. wat shud i do to use all the 4gb ???
george101 is offline
Old 14-05-2009, 05:07 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: Ony 3Gb on Vista 64bit!!!
Are you sure its 64bit ? Because I see nothing wrong with your motherboard or CPU.
Try contacting Microsoft Help about it. Thats the most reliable space to ask.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 19-05-2009, 08:18 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
Make sure you are using the latest bios. Also as far as I know youi need to enable memory remapping to show all of the 4GB ram.
BTW, what does cpu-z is showing on the mem tab. Is it 2x2GB.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now
