13-05-2009, 01:27 PM
HD 4670 or 9600GT in Rs. 8k Budget?
Hello,
I am having a hard time deciding between HD4670 and 9600GT. I have a budget of Rs. 8k . Please suggest which is better and if there any other GFX card for Rs. 8k which is better than these two.
Thanks!
13-05-2009, 01:59 PM
Re: HD 4670 or 9600GT in Rs. 8k Budget?
What psu do you have ? If you do not have quality psu, the best option is
Palit radeon hd 4770 for 6.5k
zebronics 350w pro for 1.5k
If you have good brand psu already,
Palit GTS 250 for 7.5k
13-05-2009, 05:42 PM
laborare est orare
In ur 8k budget, why r u opting for those lower middle performance card. In this price u can easily have a good performance card. opt for Nvidia 9800 GT or radeon HD 4830/4770 based cards
Price:
Palit GTS 250 512MB GDDR3 @ 7.7K
Palit 9800GT 512MB GDDR3 @ 6.5k
Sapphire HD4770 512MB GDDR5 @ 7.2k
MSI HD4770 512MB GDDR5 @ 6.6k
13-05-2009, 07:48 PM
nothin beats HD 4770 in that price range. it one hell of a card with gr8 oc potential and consumes much less power than a 9800GT.
4770 oc can beat 4850 or GTS 250 with ease.
G3: XPS M1530 |
FZ 16.
14-05-2009, 07:43 PM
Thanks for the suggestion guys! Any more suggestions? I need to make it final so that I don't regret later.
Thanks!
14-05-2009, 07:57 PM
go for HD4770...I'm sure u wont regret on dat decision.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
14-05-2009, 08:15 PM
Point Blanc
NO
14-05-2009, 08:16 PM
Originally Posted by acewin
NO
No for what?
15-05-2009, 08:36 AM
Point Blanc
NO for your thread name n yes hor HD4770
15-05-2009, 06:53 PM
laborare est orare
No doubt 4770 is one of the best cards around. But I will suggest go for a 1GB version of 9800 GT/GTS 250 or 4850. Bcoz today's game r very demanding n they need a very high amount of memory for the huge amount of textures to create life like view. here spending of extra 1.5/2k really worth it. 4850 is having the computing power 'n if equipped with 1 GB of memory, it can be unbeatable at this price range.
15-05-2009, 07:07 PM
Palit radeon 4770 not available i think.
u can visit their site: http://www.palit.biz
Last price i m getting in SP road, Bangalore for this card(sapphire) is 7,650(with tax). waiting for few more days.
you need to invest on good psu for this card.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
15-05-2009, 10:49 PM
more amount of GPU memory is utilized only if u are planning to play at HD resolutions on a HD monitor, otherwise the results r same. btw a overclocked HD4770 can easily beat a HD4850 or a GTS250.
yup, Palit HD4770 is not yet available. Sapphire, MSI and XFX are available now in India. The Sapphire HD4770 costs only 6.5k. Some of them in this forum has already brought this card.
16-05-2009, 03:03 AM
If u ppan on using up more than 512MB of VRAM, then opt for a better card like GTX260 or 4870. Opfcouse even 4770 GPU will need more than 512MB if layed on high resolutions like 1080p or higher, but itll be the gpu thatll be the bottleneck.
For a card like 4770, 512 MB is enuf, plus its fast DDR5 even if the bus width is lower.
G3: XPS M1530 |
FZ 16.
18-05-2009, 05:41 PM
laborare est orare
4770 is not a better performer than 4850. Don't forget 4850 is having 800 SPs, compared to 640 SPs of 4770. Actually 4770 sits between 4830 and 4850. The performance difference is 10% in most of the today's game.
But if u consider performance/Price ratio or Power consumption, then u should go for 4770.
18-05-2009, 06:30 PM
very true
and 4770 do outperform a stock 4850 after oc, but cant keep up with an OCed 4850 ofcourse.
G3: XPS M1530 |
FZ 16.
21-05-2009, 10:43 PM
Bond, Desi Bond!
I feel the decision should be either HD4770 or GTX260. Because performance difference between HD4770 and HD4850 is negligible. Moreover, HD4770 is lot cooler and takes lot less power. If the budget is strictly inside 9k, HD4770 would be the best choice and if the buyer can pay 10k-11k, GTX260 without a doubt
21-05-2009, 10:49 PM
dollar value has dropped and we can see some 500 bucks reduction is prices very soon.
G3: XPS M1530 |
FZ 16.
22-05-2009, 05:08 AM
HD4770 will b very gud..& as one said, it could give performance equivalent to hd4850 if you oc it.
