Old 13-05-2009, 11:38 AM   #1 (permalink)
naughty boy :) :)
mahesh's Avatar
Question PCI TV Tuner card OR USB Tv Tuner card?
I need a tv tuner card. which type to buy? PCI TV Tuner card OR USB Tv Tuner card?
my max budget will be 2k. Is it possible to watch tv in my pc while downloading at the same time?
Phenom II 550 BE | GA-MA78GM-US2H | 160 gb + 500 gb hdd | 2 X 2 gb XMS2 | HD 4850 1 GB | 2033 SW | Tagan TG600-U37 | CM 690
mahesh is offline
Old 14-05-2009, 12:05 AM   #2 (permalink)
Point Blanc
Default Re: PCI TV Tuner card OR USB Tv Tuner card?
what do you want to download, TV tuner and downloading from net are different appliation so yes you can do both at the same time. Also you can record TV programs too at the same time.
Read this thread for your doubts, I have saved it bcoz people had given some good points
TV Tuner buying guide
acewin is offline
Old 14-05-2009, 09:19 AM   #3 (permalink)
dIgItaL_BrAt's Avatar
go for the usb tv tuner card...i'd suggest the pixelview playtv....and yes you can download simultaneously
dIgItaL_BrAt is offline
Old 14-05-2009, 10:01 AM   #4 (permalink)
naughty boy :) :)
mahesh's Avatar
Thanks
mahesh is offline
