Old 10-05-2009, 09:45 AM   #1 (permalink)
Default Suggest LCD
Hi i want to replace my old 15' LG crt with 22' LCD.
At my locality Samsung, LG, Philips & AOC are available.
My budget is max 12k
which one should i choose?
My usage will be gaming, movies and coding.
Pls also have a look at this also -
http://www.consumer.philips.com/cons...tor+220X1SW-00
sunny155 is offline
Old 10-05-2009, 10:18 AM   #2 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Default Re: Suggest LCD
It is indeed good but try SAMSUNG 2233SW or DELL S2209W both Full HD.
keith_j_snyder2 is offline
Old 10-05-2009, 01:22 PM   #3 (permalink)
Yes go as suggested samsung 2233 is really good and its in ur budget it goes a @ 10.4k... In kolkata....'
Arnab boss is offline
Old 10-05-2009, 02:29 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
+1 to Samsung 2233. Good reviews of it overall.
Blogging at:
Technostarry
saqib_khan is offline
Old 10-05-2009, 03:42 PM   #5 (permalink)
ok thanks everybody.
But have u saw the link above ?
Have u people ever tried the philips Lightframe LCD
Why i should not choose philips? pls suggest
sunny155 is offline
Old 10-05-2009, 03:44 PM   #6 (permalink)
do u people mean this samsung model -
http://www.samsung.com/in/consumer/d.../XL&fullspec=F
sunny155 is offline
Old 10-05-2009, 04:32 PM   #7 (permalink)
I like to FIFA
deadkiss 009's Avatar
^^ Yes that one, go for it. Priced at 10.5k approx.
My rig :
ASUS M2NE SLI, AMD 6400X2, 4GB DDR2@800 MHz, ZOTAC GTX 275, SAMSUNG 2233SW, CORSAIR TX 750 PSU, CM 690 CASE, CREATIVE INSPIRE 2.1
deadkiss 009 is offline
Old 10-05-2009, 05:04 PM   #8 (permalink)
i forgot to mention i have Sapphire Radeon 2600 XT 512 GDDR3 card....will i still be benefitted with this Samsung 2233SW combination with my card?
sunny155 is offline
Old 10-05-2009, 07:40 PM   #9 (permalink)
I M A *STAR*
saqib_khan's Avatar
No, u'll not be benefited with this card, because if u wanna play game in this Full HD LCD then u need min 4770 graphic card. That means a good graphic card is required to play game on this monitor.
Blogging at:
Technostarry
