Old 09-05-2009, 09:21 PM   #1 (permalink)
Tech addict
surinder's Avatar
Default Suggest best earphones under 2K
I'm looking for good in ear canal type earphones under 2K for my Ipod. I own creative's EP 630 looking for better one please suggest.
surinder is offline
Old 09-05-2009, 11:43 PM   #2 (permalink)
Default Re: Suggest best earphones under 2K
you should get in the soundmagic pl-30 they are awesome earphones .
200mph is offline
Old 10-05-2009, 08:57 AM   #3 (permalink)
Tech addict
surinder's Avatar
I found a link for that and are they better from senneheiser CX 500 for 1.5K?
http://www.techenclave.com/dealers-p...-a-132302.html
Can I get better price for the same also can I get it somewhere in Delhi?
Or somebody knows even better earphones available in India in 2K.
surinder is offline
Old 10-05-2009, 03:17 PM   #4 (permalink)
http://www.mediahome.in/index.php?op...2&Itemid=1
i think this is the best choice having read the reviews online and the response there is no doubt they are much better than anything in that price
200mph is offline
