Old 08-05-2009, 07:53 PM   #1 (permalink)
Default Nvdia 6200 wmp hardware acceleration
why for wmp hardware acceleration is disabled ? according 2 nvdia weby says it support pure video .
wikipedia says '''NVIDIA's PureVideo is a hardware feature designed to offload video decoding processes and video post-processing from a computer's CPU hardware to NVIDIA's GPU hardware series GeForce 6,;;
so y wmp not supporting hardware acceleration .
Is it hardware /software problem ? i use latest driver from nvdia website , latest direct x , chipset ,
my config
P4 2.8
zebronic 845g
768 ram
80gb h. disk
XFX 6200 graphic Agp
software installed
wmp 11
nVidia_Purevideo_Platinum_1.02.233
all system necessary drivers
win xp pro Sp3 fully updated
direct x log
System Information
Time of this report: 5/8/2009, 19:28:08
       Machine name: COMPUTER_1
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.090206-1234)
           Language: English (Regional Setting: English)
System Manufacturer: INTELR
       System Model: AWRDACPI
               BIOS: Phoenix - AwardBIOS v6.00PG
          Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz
             Memory: 768MB RAM
          Page File: 313MB used, 1436MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: NVIDIA GeForce 6200
     Manufacturer: NVIDIA
        Chip type: GeForce 6200
         DAC type: Integrated RAMDAC
       Device Key: Enum\PCI\VEN_10DE&DEV_0221&SUBSYS_21521682&REV_A1
   Display Memory: 256.0 MB
     Current Mode: 1024 x 768 (32 bit) (85Hz)
          Monitor: Plug and Play Monitor
  Monitor Max Res: 1600,1200
      Driver Name: nv4_disp.dll
   Driver Version: 6.14.0011.8250 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 3/27/2009 10:03:00, 6186880 bytes
      WHQL Logo'd: n/a
  WHQL Date Stamp: n/a
              VDD: n/a
         Mini VDD: nv4_mini.sys
    Mini VDD Date: 3/27/2009 10:03:00, 6280416 bytes
Device Identifier: {D7B71E3E-4161-11CF-0855-590100C2CB35}
        Vendor ID: 0x10DE
        Device ID: 0x0221
        SubSys ID: 0x21521682
      Revision ID: 0x00A1
      Revision ID: 0x00A1
      Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
 Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                   {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                   {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Sound Devices
            Description: Realtek AC97 Audio
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: PCI\VEN_8086&DEV_24C5&SUBSYS_4761414C&REV_02
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: ALCXWDM.SYS
         Driver Version: 5.10.0000.6260 (English)
            WHQL Logo'd: n/a
          Date and Size: 10/2/2007 17:45:04, 4109376 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Full
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: Yes, Yes
   I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x0
           Format Flags: 0x0
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: n/a
           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                  MPU-401, Hardware (Kernel Mode), Input, No DLS, External
                  MPU-401, Hardware (Kernel Mode), Output, No DLS, External
                  Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
                  Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                  MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
                  MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
        Registry: OK
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24C4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 00:15:38, 59520 bytes
| Driver: usbd.sys, 8/23/2001 16:30:00, 4736 bytes
Gameport Devices
+ Intel(R) 82801DB LPC Interface Controller - 24C0
| Matching Device ID: pci\ven_8086&dev_24c0
| Service: isapnp
| Driver: isapnp.sys, 4/14/2008 00:06:42, 37248 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 4/14/2008 05:45:30, 10624 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 05:18:02, 52480 bytes
| Driver: kbdclass.sys, 4/14/2008 04:39:48, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 05:43:22, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 4/14/2008 10:21:44, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 18.1 GB
Total Space: 21.0 GB
File System: NTFS
      Model: SAMSUNG SP0802N
      Drive: D:
 Free Space: 10.3 GB
File System: NTFS
      Drive: F:
 Free Space: 15.3 GB
Total Space: 26.0 GB
File System: NTFS
      Drive: G:
 Free Space: 7.3 GB
Total Space: 8.3 GB
File System: NTFS
      Drive: E:
      Model: HL-DT-ST DVD-ROM GDR8164B
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/14/2008 04:40:48, 62976 bytes
System Devices
     Name: Video Controller
Device ID: PCI\VEN_8086&DEV_2562&SUBSYS_25628086&REV_01\3&13C0B0C5&0&10
   Driver: n/a
     Name: Intel(R) 82845G/GL/GE/PE/GV/E Processor to I/O Controller - 2560
Device ID: PCI\VEN_8086&DEV_2560&SUBSYS_00000000&REV_01\3&13C0B0C5&0&00
   Driver: n/a
     Name: Intel(R) 82801DB/DBM USB2 Enhanced Host Controller - 24CD
Device ID: PCI\VEN_8086&DEV_24CD&SUBSYS_24CD8086&REV_02\3&13C0B0C5&0&EF
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 30208 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 74240 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 10:11:56, 7168 bytes
     Name: Intel(R) 82801DB Ultra ATA Controller
Device ID: PCI\VEN_8086&DEV_24CB&SUBSYS_24C28086&REV_02\3&13C0B0C5&0&F9
   Driver: C:\WINDOWS\system32\DRIVERS\IdeChnDr.sys, 2.03.0000.2160 (English), 10/15/2002 00:00:00, 101431 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\IdeBusDr.sys, 2.03.0000.2160 (English), 10/15/2002 00:00:00, 13891 bytes
   Driver: C:\WINDOWS\system32\IPrtCnst.dll, 2.03.0000.2160 (English), 10/15/2002 00:00:00, 44875 bytes
     Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C7
Device ID: PCI\VEN_8086&DEV_24C7&SUBSYS_24C28086&REV_02\3&13C0B0C5&0&EA
   Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 20608 bytes
     Name: Realtek AC'97 Audio
Device ID: PCI\VEN_8086&DEV_24C5&SUBSYS_4761414C&REV_02\3&13C0B0C5&0&FD
   Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (English), 4/14/2008 05:41:58, 4096 bytes
   Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (English), 4/14/2008 05:42:44, 129536 bytes
   Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (English), 4/14/2008 00:46:38, 141056 bytes
   Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:16, 60160 bytes
   Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/14/2008 00:49:42, 146048 bytes
   Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (English), 4/14/2008 00:15:16, 49408 bytes
   Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 10:21:44, 23552 bytes
   Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.6260 (English), 10/2/2007 17:45:04, 4109376 bytes
   Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0059 (English), 4/16/2007 15:28:22, 577536 bytes
   Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0073 (English), 11/17/2006 05:40:46, 18804736 bytes
   Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/5/2002 13:54:58, 141016 bytes
   Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0066 (English), 12/8/2006 15:20:14, 10528768 bytes
   Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0001.0004 (English), 10/18/2006 02:53:26, 147456 bytes
   Driver: C:\WINDOWS\Alcrmv.exe, 2.00.0000.0004 (English), 7/31/2006 11:27:30, 217088 bytes
     Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C4
Device ID: PCI\VEN_8086&DEV_24C4&SUBSYS_24C28086&REV_02\3&13C0B0C5&0&E9
     Name: Intel(R) 82801DB/DBM SMBus Controller - 24C3
Device ID: PCI\VEN_8086&DEV_24C3&SUBSYS_24C28086&REV_02\3&13C0B0C5&0&FB
   Driver: n/a
     Name: Intel(R) 82801DB/DBM USB Universal Host Controller - 24C2
Device ID: PCI\VEN_8086&DEV_24C2&SUBSYS_24C28086&REV_02\3&13C0B0C5&0&E8
     Name: Intel(R) 82801DB LPC Interface Controller - 24C0
Device ID: PCI\VEN_8086&DEV_24C0&SUBSYS_00000000&REV_02\3&13C0B0C5&0&F8
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 00:06:42, 37248 bytes
     Name: Intel(R) 82801DB PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_82\3&13C0B0C5&0&F0
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 00:06:46, 68224 bytes
     Name: Conexant 23880 Video Capture (PAL)
Device ID: PCI\VEN_14F1&DEV_8800&SUBSYS_00000000&REV_05\4&1A671D0C&0&10F0
   Driver: C:\WINDOWS\system32\kstvtune.ax, 5.03.2600.5512 (English), 4/14/2008 05:42:44, 61952 bytes
   Driver: C:\WINDOWS\system32\ksxbar.ax, 5.03.2600.5512 (English), 4/14/2008 05:42:44, 43008 bytes
   Driver: C:\WINDOWS\system32\kswdmcap.ax, 5.03.2600.5512 (English), 4/14/2008 05:42:44, 91136 bytes
   Driver: C:\WINDOWS\system32\vidcap.ax, 5.01.2600.5512 (English), 4/14/2008 05:42:44, 28672 bytes
   Driver: C:\WINDOWS\system32\vfwwdm32.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 53760 bytes
   Driver: C:\WINDOWS\system32\iyuv_32.dll, 5.01.2600.5512 (English), 4/14/2008 05:41:56, 47616 bytes
   Driver: C:\WINDOWS\system32\msh263.drv, 5.01.2600.5512 (English), 4/14/2008 05:42:46, 294912 bytes
   Driver: C:\WINDOWS\system32\msyuv.dll, 5.03.2600.5512 (English), 4/14/2008 05:42:02, 16896 bytes
   Driver: C:\WINDOWS\system32\tsbyuv.dll, 5.01.2600.0000 (English), 8/17/2001 22:36:34, 8192 bytes
   Driver: C:\WINDOWS\system32\drivers\cx88vid.sys, 4.00.0112.0000 (English), 8/15/2005 14:22:14, 190848 bytes
     Name: PCI Simple Communications Controller
Device ID: PCI\VEN_14F1&DEV_2F30&SUBSYS_205D14F1&REV_01\4&1A671D0C&0&20F0
   Driver: n/a
     Name: NVIDIA GeForce 6200
Device ID: PCI\VEN_10DE&DEV_0221&SUBSYS_21521682&REV_A1\4&1A671D0C&0&00F0
   Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 6280416 bytes
   Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 6186880 bytes
   Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 163908 bytes
   Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 667648 bytes
   Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 1560576 bytes
   Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 401408 bytes
   Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 9596928 bytes
   Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 13684736 bytes
   Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 86016 bytes
   Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 81920 bytes
   Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 229376 bytes
   Driver: C:\WINDOWS\system32\nvmccsrs.dll, 6.14.0011.8250 (Arabic), 3/27/2009 10:03:00, 45056 bytes
   Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 4710400 bytes
   Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 3489792 bytes
   Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 188416 bytes
   Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 1273856 bytes
   Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 3796992 bytes
   Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 2744320 bytes
   Driver: C:\WINDOWS\system32\NvPVEnc.ax, 6.14.0011.8250 (English), 3/27/2009 10:03:00, 1253376 bytes
   Driver: C:\WINDOWS\help\nvcpl.hlp, 3/27/2009 10:03:00, 177897 bytes
   Driver: C:\WINDOWS\help\nvwcplen.hlp, 3/27/2009 10:03:00, 55444 bytes
   Driver: C:\WINDOWS\system32\nvcod.dll, 1.04.0002.0037 (English), 3/27/2009 10:03:00, 139264 bytes
   Driver: C:\WINDOWS\system32\nvcodins.dll, 1.04.0002.0037 (English), 3/27/2009 10:03:00, 139264 bytes
DirectX Components
   ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:52 279552 bytes
 ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:52 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 16:30:00 10496 bytes
    d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:52 1179648 bytes
 d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:52 8192 bytes
    d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:52 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:30:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:52 824320 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:30:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:30:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:30:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:30:00 34816 bytes
   dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 16:30:00 33040 bytes
  dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 23552 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 16:30:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 10:12:18 29696 bytes
  dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 10:12:18 17920 bytes
   dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:09:22 3072 bytes
 dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:09:20 3072 bytes
 dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 10:12:20 83456 bytes
  dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 116736 bytes
  dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 16:30:00 53520 bytes
  dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 158720 bytes
 dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 181760 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:30:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:30:00 394240 bytes
     joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 10:12:42 68608 bytes
   gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 16:30:00 76800 bytes
     pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:21:44 35328 bytes
gameenum.sys: 5.01.2600.5512 English Final Retail 4/14/2008 05:45:30 10624 bytes
  dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 1293824 bytes
  dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 19456 bytes
   dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 71680 bytes
  dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 104448 bytes
  dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 61440 bytes
   dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 35840 bytes
 dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 105984 bytes
 dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 82432 bytes
   dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 619008 bytes
   dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 1227264 bytes
 dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 2113536 bytes
   mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 16:30:00 924432 bytes
   mfc42.dll: 6.02.4131.0000 English Final Retail 4/14/2008 10:11:58 1028096 bytes
 wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 10:12:12 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:11:50 70656 bytes
 devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:11:52 59904 bytes
  dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 10:11:54 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:11:58 35328 bytes
 mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 10:12:44 148992 bytes
   msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:12:00 14336 bytes
  encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:11:54 20480 bytes
    qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
    qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:12:04 192512 bytes
     qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:12:04 279040 bytes
    qdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:12:04 386048 bytes
   qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:12:04 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/14/2008 03:21:34 733696 bytes
  quartz.dll: 6.05.2600.5731 English Final Retail 12/21/2008 03:44:38 1288192 bytes
 strmdll.dll: 4.01.0000.3937 English Final Retail 10/3/2008 15:32:42 247326 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 10:12:44 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 10:12:44 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 10:11:56 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 10:11:56 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 10:11:56 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 10:11:56 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 10:11:56 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 10:12:44 154624 bytes
mswebdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:12:02 203776 bytes
      ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:46:38 141056 bytes
  ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 129536 bytes
  ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:58 4096 bytes
  stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 05:39:52 5376 bytes
   mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 05:39:52 4992 bytes
 mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 05:39:54 7552 bytes
  swenum.sys: 5.03.2600.5512 English Final Retail 4/14/2008 10:21:44 4352 bytes
   mstee.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:52 5504 bytes
   ipsink.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 16384 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 10:12:44 118272 bytes
  ndisip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:24 10880 bytes
streamip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:22 15232 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 10:12:02 1428992 bytes
    slip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:24 11136 bytes
nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:26 85248 bytes
ccdecode.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:24 17024 bytes
  vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 10:12:44 30208 bytes
   msyuv.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:02 16896 bytes
 kstvtune.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 61952 bytes
   ksxbar.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 43008 bytes
 kswdmcap.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 91136 bytes
vfwwdm32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 05:42:10 53760 bytes
wstcodec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:16:26 19200 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 10:12:12 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.5512
CC Decoder,0x00200000,2,1,,5.03.2600.5512
WST Codec,0x00200000,1,1,,5.03.2600.5512
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Sample Infinite Pin Tee,0x00200000,1,1,inftee.ax,9.00.0000.0000
NVIDIA Video Post Processor,0x00200000,1,1,nvvpp.ax,4020.223.0000.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5731
NVIDIA Cd Audio Reader,0x00200000,0,1,NvCdaRdr.ax,4020.223.0000.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5731
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5731
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5731
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
HT MPEG Audio Decoder,0x005fffff,1,1,HTMpegAD.ax,1.00.0000.0004
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
MainConcept MPEG Splitter,0x00600002,1,2,mcspmpeg.ax,1.00.0000.0050
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5731
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
honestech Deinterlacer,0x00200000,1,1,htdeinterlacer.ax,8.01.0000.0000
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5731
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5731
Dump,0x00200000,1,0,dump.ax,9.00.0000.0000
Genesis VBI Sink,0x00800000,1,0,GDI VBISink.ax,5.05.0000.0019
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
WAV Dest,0x00200000,0,0,wavdest.ax,
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5731
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5731
HT MPEG Video Decoder,0x00600000,1,1,HTMpegVD.ax,1.00.0001.0004
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
honestech Mpeg1/2 Recorder Filter,0x00200000,2,0,htmpeg2enc.ax,1.00.0000.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5731
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
HT File Source (Async),0x00400000,0,1,HTFileAsync.ax,1.00.0000.0000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
NVIDIA TS Info Parser,0x00200000,1,1,nvtsinfo.ax,4020.223.0000.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5731
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5731
NVIDIA Audio Decoder,0x00800001,1,1,nvauddec.ax,4020.223.0000.0000
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5731
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5731
DownSize Filter,0x00200000,1,1,DownSize.ax,2.00.0000.0000
NVIDIA Video Decoder,0x00800001,2,3,nvviddec.ax,4020.223.0000.0000
NVIDIA Transport Demux,0x00800101,1,2,nvtrpdemux.ax,4020.223.0000.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
MyGetImage Filter,0x00200000,1,1,snap.ax,1.00.0000.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
DispOptim Filter,0x00200000,1,1,DispOptim.ax,2.00.0000.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5731
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
NVIDIA MultiSource Filter,0x00000000,0,1,NvMultiSource.ax,4020.223.0000.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5731
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5731
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5731
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5731
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5731
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5731
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5731
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Honestech Video Invert Filter,0x00200000,1,1,ht_invert.ax,1.00.0000.0001
NVIDIA Navigator,0x00600000,0,3,nvnav.ax,4020.223.0000.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
NVIDIA ATSC File,0x00200000,0,1,nvatscfile.ax,4020.223.0000.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5731
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5731
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5731
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
TOP10Disp Filter,0x00200000,1,1,TOP10Disp.ax,1.00.0000.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
HT MPEG TimeShift,0x00200000,1,2,HTMpegTimeshift.ax,1.00.0000.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5731
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5731
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.5512
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5731
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5731
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5731
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5731
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5731
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5731
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5731
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5731
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5731
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5731
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5731
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5731
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5731
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5731
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5731
MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.5731
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Conexant 2388x Video Capture,0x00200000,1,3,,5.03.2600.5512
Realtek AC97 Audio,0x00200000,3,3,,5.03.2600.5512
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.5512
Video Capture Sources:
WDM Streaming TV Tuner Devices:
Conexant 2388x Tuner,0x00200000,0,2,,5.03.2600.5512
WDM Streaming Crossbar Devices:
Conexant 2388x Crossbar,0x00200000,7,2,,5.03.2600.5512
WDM Streaming TV Audio Devices:
Conexant 2388x TvAudio,0x00200000,1,1,,5.03.2600.5512
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
WDM Streaming Communication Transforms:
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.5731
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5731
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5731
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.5731
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.2600.5512
Realtek AC97 Audio,0x00200000,16,2,,5.03.2600.5512
BDA Receiver Components:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
Links wr i got infos
http://www.nvidia.com/page/geforce6200_agp.html
http://en.wikipedia.org/wiki/NVIDIA_PureVideo
Rajesh345 is offline
Old 13-05-2009, 08:30 PM   #2 (permalink)
Default Re: Nvdia 6200 wmp hardware acceleration
even after 1+ week no rply , comeon guys tell something
Old 13-05-2009, 09:15 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
is it affecting anything, i mean maybe it's already on you know!
BTW: Performance TIP-
1. Increase Page file to 2GB
2. Make your 6200 a 6600(possible) and OC to make it 6600GT(for free, tada!)
About me:
http://about.me/preetam_nath
comp@ddict is offline
