Old 06-05-2009, 11:25 AM   #1 (permalink)
Talking Is this PSU enough for this RIG???
cabinet
Zebby Antibiotic
Cd drive
Sony 22X Internal DVD-RW AD-7220S
Graphics card
Palit GeForce™ 9600GT 1GB DDR3
Hard disk
WD caviar black 1TB SATA Internal HDD
Motherboard
GA-P31-ES3G
PSU
Corsair VX450
Processor
Intel Core 2 Duo Desktop Processor E7400
ram
Kingston ram 2gb 800mhz
so guys i want to go for this config now say if all's good or not..???
sanjeev choudhary is offline
Old 06-05-2009, 01:11 PM   #2 (permalink)
damn busy...
utsav's Avatar
Default Re: Is this PSU enough for this RIG???
The PSU is gud enuf
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 06-05-2009, 01:55 PM   #3 (permalink)
Get radeon 4770 for 6.5k instead of 9600gt. It's almost 1.5 times faster.
hsetir is offline
Old 06-05-2009, 04:06 PM   #4 (permalink)
Your worst nightmare
pavasedge's Avatar
I already told you not to go for 1GB graphics card.Its not needed if u don't play at higher resolutions.9600GT is a mid range card,it can only handle games at meduim resolutions.Yes your PSU is very good.But I suggest better go for Cooler Master 600W PSU and Radeon HD4770.Corsair is better than CM but CM is good too.
pavasedge is offline
Old 06-05-2009, 04:16 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Dude, change ur config to this:-
- Kingston 4GB DDR2 800MHZ @ 1.9k
- Corsair VX450W @ 3.9k
- Zotac GTX260 @ 10.3k(from lynx-india)
This card, GTX260, is "x" times better than a 9600GT, and "x" here is a BIG number. It's worth it.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 06-05-2009, 04:44 PM   #6 (permalink)
the reason i'm going for palit card is that i want hdmi port to connect to my LCD i dunn have ant#y monitor so i will put it on 32" LCD tv and it has that option and second#d thing is that it will support future games too.
Old 06-05-2009, 05:45 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
I think HD4770 models come with HDMI conn. or u can get a converter for 700 bucks. dude, get a better card.
About me:
Old 06-05-2009, 06:28 PM   #8 (permalink)
BUT then i think i would have to change my motherboard as well.....what do u say???
coz of ATI........!!!
Old 06-05-2009, 06:51 PM   #9 (permalink)
damn busy...
utsav's Avatar
Who said to u that u gotta change mobo? Only sli and crossfire is mobo dependent. You can use any GPU brand in any mobo if it has PCI-E slot
www.techjunkiez.com
utsav is offline
Old 06-05-2009, 07:08 PM   #10 (permalink)
Gowt1ham
Gowt1ham's Avatar
^^^^^^^^^No, u can use it on ur rig no problem. However it wont support hybrid power saving like on 790gx motherboard.
If u are playing @ 1920 X 1080 on 22"+ monitor better get HD 4850/HD 4870 1GB DDR5.
No use of 1Gb on low end GPU.
PII 965 BE @ 4ghz|CM 10 |8GB GSKILL Ripjaws|Aerocool V12|MSI 790gx g70|EVGA GTX 260 OC |CM UCP 900W| CM Stacker 830 nvidia Edition+13 fans| BenQ 24"| Logitech G15 & MX 518| 2TB HDD|AD700+E7/E9
Gowt1ham is offline
Old 06-05-2009, 07:15 PM   #11 (permalink)
Talking Re: Is this PSU enough for this RIG???
cabinet
Zebby Antibiotic
Cd drive
Graphics card
ATI Radeon™ HD 4770
Hard disk
Motherboard
gigabyte GA-P31-ES3G
PSU
Corsair VX450
Processor
ram
then i guess this would be my final config as the budget is limited...hehehe....
Old 06-05-2009, 07:22 PM   #12 (permalink)
maverick786us's Avatar
1) No stick to Corsair PSUs. Corsair provides quality PSUs with unimaginable power.
2) Instead of Kingston go for either G-Skill, Corsair, OCZ or patriot. Very good for Overclocking with life time warranty. First 2 are the best choices.
3) Go for good Casing like CM 690 or 590 Centurian. If you are looking for a good gaming rig then your CPU Case should allow your circuit to breath
(Gaming Rig) Intel E8400 @ 3.6Ghz, ASUS P5Q Pro, 4GB G.Skill DDR2 800, WD 6400AAKS HDD, MSI Cyclone GTX 460, Corsair 650TX, CM 690, Dell SP2208WFP (22 inch), Windows 7 Ultimatum 64
maverick786us is online now
Old 06-05-2009, 09:04 PM   #13 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
ATI Radeon™ HD 4770
okay, stay with this card, but atleast change these:-
PSU - Corsair CX400W @ 3.2k
RAM - 2*2=4GB DDR2 800MHz Kingston @ 1.9k
So, u're saving on PSU, and using that for RAM.
A VX450W would go waste, so save the extra k, and use that for RAM.
About me:
Old 07-05-2009, 12:28 AM   #14 (permalink)
k thanx for the tip so ur saying that 400W will be enough for this config u sure coz i was thinking to OC this pc upto 3.4 instead of current 2.8. so in that case i will need some cooling rite..!!!
p.s r u sure that i,ll get kingston for that price coz we i checked it was like 1.3k for 2 gb
Old 07-05-2009, 10:53 AM   #15 (permalink)
so what is the diffrence b/w
sapphire radeon hd 4770 and ati radeon hd 4770
is there any price diffrence in b/w them or only company diffrence, and what would be a better option?
Old 07-05-2009, 11:20 AM   #16 (permalink)
dOm1naTOr's Avatar
there are no practical ATI radeon 4770 cards, and are just sample models.
u will find 4770 only from some vendor like sapphire/palit/gecube etc.
sapphire 4770@7.2k
palit 4770@6.7k
and if u intend on high resolution, get a 4850 with 1Gb or somethin, oe even GTX 260@11k with the corsair VX450 or Antec earthwatt EA 500.
both are equally gud, antec being slightly cheap.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 07-05-2009, 11:29 AM   #17 (permalink)
Red face Re: Is this PSU enough for this RIG???
sapphire 4770@7.2k
palit 4770@6.7k
okk thanx will definitely consider that.
btw how bout OC all of my config i.e frm CPU ,,RAM AND GRAPHICS CARD can any body come up with sm nice combination for them all.
thanx
Old 07-05-2009, 12:04 PM   #18 (permalink)
-anmol-'s Avatar
Brother ,that G31 Momboard is best suited for a E5200.
When you buy a processor like the E7400 which is a superb overclocker, buy a P45 or atleast a P43 to do justice to your proccy.When you are buyn a rig like that atleast get a platform thats strong,which will benefit all of your prized components.
Give it a thought.
-anmol- is offline
Old 07-05-2009, 12:35 PM   #19 (permalink)
Bond, Desi Bond!
desiibond's Avatar
@sanjeev, I don't think Palit has released HD4770.
Available brands:
Sapphire
MSI
XFX
The card from these three brands looks identical top to bottom and the copper cooler on these three looks to be better than that in reference card as it is bigger and fan too is bigger.
desiibond is offline
Old 07-05-2009, 12:42 PM   #20 (permalink)
Point Blanc
anf also G31 are not that good for overclocking
acewin is offline
Old 07-05-2009, 12:54 PM   #21 (permalink)
Available brands:
Sapphire
MSI
XFX
very true bro i figured it out that palit dont have 4770 so for the final touch to this RIG can u tell me which one of them is less costly option in DELHI(comparing the prices of diff manufacturers):
hd 4770 (cheapest of them: sapphire,msi,xfx)
p43 (cheapest of them :asus,gigabyte,mercury)
and then my rig will be complete.
thanx
Old 07-05-2009, 12:57 PM   #22 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I would go for Sapphire as XFX is costlier and I don't rely on MSI that much.
I paid 7.2k for Sapphire yesterday. Can't you wait for some more time (for others to release with more custom coolers).
Old 07-05-2009, 01:28 PM   #23 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
512MB HD4770
new card huh?
do a review if possible.
About me:
Old 07-05-2009, 02:02 PM   #24 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^sure will do but am waiting for the proper drivers as the drivers that came with the card sucks. win7 user experience rating fell from 5.1 to 2.0 for graphics (earlier it was HD2600XT) and I am getting 10-12fps framerate in Far Cry 2.
Old 07-05-2009, 03:58 PM   #25 (permalink)
Unhappy Re: Is this PSU enough for this RIG???
but the main thing is i'm asking for the price coz i cant go much high.. so i need the cheapest of them all:
cheapest option for hd 4770 & p43 mobo.....??? (again for delhi)
Old 07-05-2009, 04:35 PM   #26 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
MSI HD4770
Stay with G31 Gigabyte, it will allow 3.4GHz easily.
or also ASUS G31.
AMD 3000+ @ 2.3Ghz, 4x512Mb ddr400, gigabyte GA-K8n51GMF-9,
Y dun u change this to something like:-
X2 7750 B.E. @ 3.2k
780G based @ 3.2k
4GB @ 1.9k
About me:
Old 07-05-2009, 04:36 PM   #27 (permalink)
Bond, Desi Bond!
desiibond's Avatar
you better get a Crossfire enabled board because HD4770 is one hell of a card for crossfire setup. Get HD4770 now and later add one more in CF setup to speed up the system.
But if you are going to get a FullHD display, you better get a better card.
Old 07-05-2009, 04:47 PM   #28 (permalink)
u see i'm gonna go for a cheaper option for now may be next yr i'll but another 4770 and new upgraded crossfire enabled mobo as for now this is the peak.
so will have to see frm whr i can get all this stuff as is hard to find ATI products in delhi.(geforce are pretty common).
as well i cant go w/o intel as amd had verry bad past with me. :s
Old 07-05-2009, 07:14 PM   #29 (permalink)
-anmol-'s Avatar
First let ATI come out with working drivers for a single card to work to its full potential and then think about CF.
-anmol- is offline
Old 07-05-2009, 09:08 PM   #30 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^If wid these drivers th CF performance is such, I wonder how good a fully optimized driver performance would be!
About me:
