Old 04-05-2009, 09:32 PM   #1 (permalink)
Smile new pc oveclocking tips plz help!!!!!!
hello ppl i,m buying a pew pc which should be good for multimedia activities as well as good gaming so i came out of this configuration which comes in my budget just a lil adjustments can be made. BUT THE THING IS i have no idea as if all these products will be compatible after assembling so i need some EXPERT ADVICE on making this a perfect pc which should last long w/o any problems.....,so the config goes...:-
cabinet
Zebby Antibiotic
Cd drive
Sony 22X Internal DVD-RW AD-7220S
Graphics card
Palit GeForce™ 9600GT 1GB DDR3(pretty good feedback)
Hard disk
Seagate 1 TB SATA Internal HDD
Motherboard
Gigabyte GA-EG31M-S2 LGA775
or
gigabyte GA-P31-ES3G
Smps
Cooler Master Real Power Pro 650W (price too..????)
Processor
Intel Core 2 Duo Desktop Processor E7400 (can it be overclocked???)
ram
kingston 2 gb 800mhz
its just the CPU so tell me if every thing is compatible to each other or do i need sm changes but really in same budget....
so guys i think i can take these changes so faar....jus tell me if alls gud and i want an overclocked cpu as well RAM if possible as my graphics card is already oveclocked....so .....temme...!!!!
thanxxx
sanjeev choudhary is offline
Old 04-05-2009, 09:46 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: new pc, compatibility problem,plz help!!!!!!
^What IS your budget?
My site: collegeclassroom.org
amitash is offline
Old 04-05-2009, 09:52 PM   #3 (permalink)
well with this config in delhi its like 25k. asked today itself.
so i can stretch a lil or reduce a lil on some things or the other but it should be in nearly same price range.
Old 05-05-2009, 10:57 AM   #4 (permalink)
Your worst nightmare
pavasedge's Avatar
Case-Zebronics Antibiotic(Peace and Reaper are also good)
Graphic card-Go for 512mb 9600GT
Hard disk-Seagate
Motherboard-Go for ASUS P5K PLCM.Gigabyte is good too.
Rest is fine.
pavasedge is offline
Old 05-05-2009, 11:30 AM   #5 (permalink)
Wink Re: new pc, compatibility problem,plz help!!!!!!
OK so i came up with cm changes and think everything is pretty fine here........but just need sm advice for overcolacking the PROCESSOR(max limit with same heatsink) AND RAM whichever is possible and HOW??????????????? u getting me....!!!!!!!
m waitinggg.....^_^
Old 05-05-2009, 09:16 PM   #6 (permalink)
Unhappy Re: new pc, compatibility problem,plz help!!!!!!
cmon guys no comments at all....tel me what to change in this configuration as well if all are good for an overclocked pc.
Old 06-05-2009, 06:04 PM   #7 (permalink)
Intel OCer
amitash's Avatar
^change 9600gt to 9800gt...only 1k more...or go for a hd4770...E7400 can easily be overclock, just google for guides....as for power supply, dont get cooler master, they have a bad rep, get the corsair vx450 for 4k...your mobo might be a bottle neck to OCing...get a better one like the MSI p43 neo f for 4.5k
amitash is offline
Old 06-05-2009, 07:16 PM   #8 (permalink)
cabinet
Zebby Antibiotic
Cd drive
Graphics card
ATI Radeon™ HD 4770
Hard disk
WD caviar black 1TB SATA Internal HDD
Motherboard
PSU
Corsair VX450
Processor
ram
Kingston ram 2gb 800mhz
then i guess this would be my final config....what say???
Old 06-05-2009, 11:35 PM   #9 (permalink)
Intel OCer
amitash's Avatar
I say increase RAM to 4gb...only 2.3k for 4gb transcend ddr2 800...and still try to change to the MSI p43 neo f mobo if your an overclocker
amitash is offline
Old 07-05-2009, 12:31 AM   #10 (permalink)
thanx but as i said the budget is pretty tight so i think its kinda hard...may beee....
