Old 03-05-2009, 01:25 PM   #1 (permalink)
Unhappy Help!! System Fan Stops!! Intermittently
I seem to have endless problems with my PC!
The latest in the long set of probelems is the system fan.
When I power-on my pc the sysytem fan starts-up. Then stops ( a long beep is heard). Then starts again(sometimes).
I have verified that the connections are fine and nothing is obstructing the fan.
Do I have to replace the fan or Is something loose on the motherboard?
What can the matter be?
I might as well add that this happens once in a while!
~RKR
Ravi Kiran Rao is offline
Old 03-05-2009, 01:32 PM   #2 (permalink)
Default Re: Help!! System Fan Stops!! Intermittently
Config:
Intel E7400, Gigabyte EG41-MF-S2H, 2GB RAM(Hynix- DDR2), CoolerMaster 390W, Win-XP
Old 03-05-2009, 03:11 PM   #3 (permalink)
uchiha_madara's Avatar
Are you able to reach the BIOS screen when you boot?
"Any sufficiently advanced technology is indistinguishable from magic"
Clark's Law
uchiha_madara is offline
Old 04-05-2009, 09:37 AM   #4 (permalink)
Oh Yes! I am able to reach the BIOS screen and later as well.
Actually evrything including the PC operation is fine. Only issue I see is that that chasis fan stops and a long beep is heard.
I have noticed that once the Win-XP screen appears the fan restarts automatically. I have verified that all components are fixed properly including the fan-connections.
~RKR
Old 04-05-2009, 09:37 AM   #5 (permalink)
~RKR
Old 04-05-2009, 11:44 AM   #6 (permalink)
download and burn memtest86 onto a CD and boot from it and let it run for a couple of hours, this will rule out any memory problems.Also, read your mobo manual to find what the beep is all about.
Clark's Law
