Old 03-05-2009, 01:12 AM   #1 (permalink)
Living to Succeed
ajayashish's Avatar
Default URGENT: Compaq SG3540 Driver for XP
I bought a Compaq SG3540 machine last day and got XP installed on it. Now when i go to Compaq site for driver download they only give driver for Vista. I need them for XP...
Please someone help me as i am unable to use the PC... no sound... no good display and no lan... please help
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 03-05-2009, 02:29 AM   #2 (permalink)
Default Re: URGENT: Compaq SG3540 Driver for XP
Which driver do you need?
rohan-04 is offline
Old 03-05-2009, 02:33 AM   #3 (permalink)
see the sound for me to do was very hard! but i found somethings in google and it worked,for the lan you will need to go to your Hardware manager and see the chip you have and go to the site and download it! and also with your GFX chip you will need to log on to the site and download the xp drivers!
btw you can try out some off the vista drivers some work on xp!
rohan-04 is offline
Old 03-05-2009, 07:07 AM   #4 (permalink)
Living to Succeed
ajayashish's Avatar
all of them... sound.. lan... gfx...
Old 03-05-2009, 02:41 PM   #5 (permalink)
Living to Succeed
ajayashish's Avatar
I downloaded some of the vista driver but they dont work on XP and says there is a windows mismatch...
I tried searching google and was helpless... i even saw the site and they are only giving Vista and Vista 64bit drivers...
Old 05-05-2009, 05:22 PM   #6 (permalink)
jatt's Avatar
I can give you if you pm me.thanks
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 06-05-2009, 06:12 PM   #7 (permalink)
Point Blanc
try uniblue driverscanner, it will search and help you update the drivers for the system
acewin is offline
