Old 02-05-2009, 11:28 PM   #1 (permalink)
Question Should i buy 8600gt with this spec?
I have C2D 6420, 1gb of ram and asus p5b-vm motherboard.
I am getting a 8600gt for about 2.5k which is 1 yrs old.
Its specs are - xfx special edition card...512mb ddr3 540mhz core and 1400mhz memory speed.
I should also mention that the smps is 400w.
Now suggest me whether i sjould go for this card or not
I dont have any idea about graphics cards.
U all suggest me what should i do.
Thank u....
The most unkowlegeable person on the http, plz tech me!!!
techani is offline
Old 02-05-2009, 11:32 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Should i buy 8600gt with this spec?
better add another 2k and get HD4650
desiibond is offline
Old 03-05-2009, 10:59 AM   #3 (permalink)
Thanks desibond for that suggestion. But can u explain ur choice a bit.
Any other suggestion about whether i should go for that card or not?
Plz guys i need a proper guidance...
techani is offline
Old 03-05-2009, 11:37 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
HD4650 is lot lot faster than 8600GT. 8600GT has become pretty old and its not good for latest games. If your budget is strictly inside 5k, get HD4650
if less than 6k, get HD4670
if less than 7k, get 9800GT or wait for HD4770
At this point of time, I wouldn't go for 8600GT and that too XFX card (xfx 8600GTs are nuclear reactors)
Old 03-05-2009, 07:04 PM   #5 (permalink)
Haha `Nuclear Reactors`! Ok buddy as u say. Now lets see how much i can manage and i will buy accordingly...
Thank u.
techani is offline
Old 03-05-2009, 07:56 PM   #6 (permalink)
dOm1naTOr's Avatar
but still 8600GT 512 DDR3 for 2.5k with 2 yr warranty left is a steal.
4650 is sure better than 8600GT, but not worth xtra 2k....as its still not better than old 8600GTS.
Moreover its the 8600GT 256 UDF7 which are electric stoves. And this 8600GT 512 DDR3has diff revision number, and is not counted among those faulty models. And 512DDr3 versions is lot better than 256 DDR3.
And yes, if there is a choice b/w a new 8600GT and 4650, u shud kick the 8600GT right away which will cost u close to 4k for 512 ddr3.
And if u CAN stretch to 5k budget, then its another case. Uhave the choice among 4670 and 9600GT. Both perform almost same with the latter consuming much greater power[ull need another PSU].
palit 4670@4.5k
palit 9600GT@5k
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 03-05-2009, 08:02 PM   #7 (permalink)
j1n M@tt's Avatar
Palit HD4670 512MB GDDR3 is now only 4.3k. It is far better than HD4650 @4k.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 03-05-2009, 11:20 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^sure that HD4670 is available for 4.3k?? if yes, then it's a damn good option.
@dominator, there is a difference between HD4650 and 8600GT. When 8600GT can give 20-25fps in a game, then even a 5fps increase from HD4650 or HD4670 makes hell lot of difference. And I do think that HD4650 is much more (than 5fps) faster than 8600GT.
Old 03-05-2009, 11:26 PM   #9 (permalink)
j1n M@tt's Avatar
^^ITwares' Rahul is selling HD4670 for 4.3k.
j1n M@tt is offline
Old 03-05-2009, 11:43 PM   #10 (permalink)
dOm1naTOr's Avatar
ofcourse 4650 is much faster...
but consider that specific 8600Gt 512 DDr3 for 2.5k....4650 seems to have less bang for the buck.
ie, @ 2.5k it a gr8 deal, if he has only less than 3k to spend.
Ofcourse 4670@ 4.3k is awesome.
G3: XPS M1530 |
FZ 16.
Old 03-05-2009, 11:46 PM   #11 (permalink)
j1n M@tt's Avatar
^^+1
ya for 2.5k, 8600GT is a gr8 deal
j1n M@tt is offline
Old 03-05-2009, 11:48 PM   #12 (permalink)
I M A *STAR*
saqib_khan's Avatar
techani, go for 8600 GT, if u r getting it for 2.5k then its a good deal.
Blogging at:
Technostarry
saqib_khan is offline
Old 04-05-2009, 11:56 PM   #13 (permalink)
Thanks guys for the help. I have more or less decided to go for the card.
Now just one thing which came to my mind. Does it have a dvi port?
techani is offline
Old 05-05-2009, 08:19 AM   #14 (permalink)
I M A *STAR*
saqib_khan's Avatar
^^ Yes , it has DVI port.
Blogging at:
Technostarry
Old 05-05-2009, 11:33 AM   #15 (permalink)
dOm1naTOr's Avatar
dual DVI
G3: XPS M1530 |
FZ 16.
Old 05-05-2009, 03:58 PM   #16 (permalink)
Point Blanc
well there is old card Palit HD3850 SUPER 512MB GDDR3 @ 4.4k
Palit HD4670 512MB GDDR3 SUPER @ 4.5k
HD3850 is better than HD4670
acewin is offline
Old 05-05-2009, 04:07 PM   #17 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Get Palit HD4670 512MB GDDR3 SUPER @ 4.8k
Since u don't have a good PSU, this is ur only option. Otherwise it wud have been an HD3850, which is faster than HD4670 too, by quite some margin in some games thanks to nearly double bandwidth.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 05-05-2009, 09:16 PM   #18 (permalink)
dOm1naTOr's Avatar
seriously 3850 is powerful that 4670?
3850 lost to 9600GT, those days and its a tie b/w 9600GT and 4670 now.
also 3850 consumes power close to 4850 and has similar size and design.
G3: XPS M1530 |
FZ 16.
Old 06-05-2009, 03:57 PM   #19 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
HD3850 is better than HD4670. It OCes better too. I know it's a hot beast, but fan fix helps, a lot. And finally, this card can do a 800MHz core and 1100MHz memory, matching 9600GT or overtaking it in performance.
About me:
Old 06-05-2009, 05:55 PM   #20 (permalink)
Point Blanc
yup price performance ratio of HD3850 is better than HD4670.
acewin is offline
Old 06-05-2009, 08:16 PM   #21 (permalink)
Thank u guys for the help. If I have any problem i will get back again!
techani is offline
