Phenom II x3 720 BE
ASUS M4A78-E/M4A78T-E
Corsair DDR2 1066Mhz/ DDR3 1600Mhz
CM Hyper N520
CM 690
Corsair VX450
WD 500GB Green
Now should I go for the DDR2 system or DDR3?
If DDR2 then please suggest alternatives for the mobo (good overclockers).
Are there any changes that you would like to suggest?
How much would DDR3 cost me? Which one should I purchase (Corsair/OCZ/Kingston/GSkill) ?
My budget is around 38-40k.
Need some advice on the mobo, RAM and cooler...
