Old 30-04-2009, 04:20 PM   #1 (permalink)
prateek007391's Avatar
Default Driver Of LCD Monitor
I purchased Acer X153w wide screen LCD Monitor
However when I connect it to PC the PC does not recognize it as a Wide Screen Monitor and because of it I am unable to set the proper resolution of windows from where can I get its driver
or if I can set the it is a 15inch wide screen monitor rather than plug and play monitor in XP
prateek007391 is offline
Old 30-04-2009, 04:25 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Driver Of LCD Monitor
You dont need any drivers for the screen. Are you using any dongle while connecting? Are you using DVI or analog D-sub to connect the screens?
The Sorcerer is online now
Old 30-04-2009, 04:33 PM   #3 (permalink)
iam using Dsub connection cable
the driver of X153W is not available on the Acer Website just for XP however the driver for vista is available
