Phenom II X4 920: 10.5k
Gigabyte GA-MA78GPM-DS2H : 6k
2x2GB DDR2 Kingston RAM: 2.5k
Palit GTX260 Core 216: 12k max
CM 690: 4k
Antec EA 650 Sli: 4.5k
U can take any of these combos for the money left.
Sound Card: Creative Audigy Sound balaster 7.1@1.8k
/Xonar Dx 4k
Tv tuner : leadtek TV 2000XP Globalanalog TV tuner 2k(analog)
Pinnacle hybrid TV tuner 3.8k (analog + DTV)
Speakers: Creative Inspire 5.1 : 2.2k
/Mx 5021 6k~7k
nice thanks but somehow i prefer an intel instead of amd
Aww man, for a budget of 45k This is the best config u can have(I can call this high end config). If u can increase ur budget to 80k may be u can choose the best Core i7 based rig and watch the price halve in 6 months.
@agx007, don't understand why are you are ready to pay more for lower performance. Anyways, go for config given by Gowtham for Intel rig but I bet Phenom II X4 will effortlessly beat core2duo and Q6600. And Q9550 is 5k costlier and with Phenom II X4, you can put that 5k in GPU and get a much much better GPU like GTX275.
Unless you go for core i7, there is no reason in sticking to Intel-only thoughts!!!
Dont go for Q6600, 720BE outstrips it and is priced lesser.
True Q6600 is almost extinct.Go for Q8200 instead or wait for i7 prices to come down.If you can wait i suggest you wait and go for a i7 rig,it is far better than core2duo's and i7 is better still coz memory controller is built in like AMD.No southbridge bottlenecks.Good for gaming and processor heavy work.
Currently
i7-920 / 2.66 GHz retails for 15850
Intel DX58SO X58 retails for 15350
Stricly out of budget.
Don't go for X4 you'll regret later,these are not bad but C2Q are better.If you are on budget X3 & X4 are good buy though.
You can buy i7-920 instead of Q9550.
well im convinced and ill go for the amd config.
But with this will i be able to play crysis and other games at high revolution as i do play games sometimes [new]
Well, I was able to play Crysis at 1280x1024 resolution on high settings with a Geforce 9600 GT on my q6600 with decent frame rates (30-45 fps). That's the max res my monitor can pump out. A GTX 260 will totally rock with Crysis or even the ATI HD 4870.
Thats great thanks everyone then ill go with this
CM 690: 4k
Seagate ST3750528AS 6k
