Old 26-04-2009, 03:30 PM   #1 (permalink)
ay_aceoo7's Avatar
Default wat's the cost of 4gb ddr2 ram{800 mhz}?
wat's the cost 4 gb ddr2 800mhz ram and also i want to buy a Graphics card tat is above 9series and the price shuld be below 5k?
ay_aceoo7 is offline
Old 27-04-2009, 10:28 PM   #2 (permalink)
Default Re: wat's the cost of 4gb ddr2 ram{800 mhz}?
For graphics card u won't find above 9 series in that budget...' u can go 4 xfx 9600 gt @ 5.4k
For ram zion 2gb ddr2 1066 mhz costs @ 1350 so 800mhz will cost around 1275... So multiply that with 2...'
Arnab boss is offline
Old 28-04-2009, 12:56 PM   #3 (permalink)
Point Blanc
not zion check kingston or transcend they are good
acewin is offline
Old 28-04-2009, 02:15 PM   #4 (permalink)
RMN
Transcend 2 gb @800mhz costs around 1100rs
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 28-04-2009, 05:33 PM   #5 (permalink)
Gowt1ham
Gowt1ham's Avatar
@ ay_aceoo7
HD4670 512MB GDDR3Super comes very close to 9600gt perfomance wise.
Radeon cards perform beter at higher resolution.<Price 4.5
PII 965 BE @ 4ghz|CM 10 |8GB GSKILL Ripjaws|Aerocool V12|MSI 790gx g70|EVGA GTX 260 OC |CM UCP 900W| CM Stacker 830 nvidia Edition+13 fans| BenQ 24"| Logitech G15 & MX 518| 2TB HDD|AD700+E7/E9
Gowt1ham is offline
