Old 26-04-2009, 09:11 AM   #1 (permalink)
atb
Default Need urgent help related to XGX8600Gt problems
Hi guys... firstly i would like to introduce me as a new member...
ok...i recently got a new system...specs are as follows
motherboard:gigabyte GA-G31M-S2L
cpu: core2 duo @2.8 ghz
kingsten 4gb of ram
western digital 320gb sata hdd
XFX 8600 GT card
I am having problems with my 8600gt....
I am having 2 DVI display outputs..and have got a DVI to VGA converter with the card.....and i use the converter to connect it to my vga pin....
when i fit my 8600 gt in my motherboard and boot i get all text and colors garbled up in the start bios screen....also my window display is the same....ie at the lowest color setting ie 4bit and garbled....
i tried to install the drivers from the cd...but in vain.... my device manager always shows a question mark for 8600Gt in my device manager...even after installing the drivers...
when i switch to onboard graphics all works fine....
I checked bios it is set to detect pci graphics if it is plugged in otherwise it will use onboard graphics...
Is this due to the DVI 2 VGA convertor or adapter???
can any one please suggest me some solution to this....its a new system and i have not able to played a single game on it....
atb is offline
Old 26-04-2009, 09:36 AM   #2 (permalink)
Tech addict
surinder's Avatar
Default Re: Need urgent help related to XGX8600Gt problems
Remove your GFX card on power off stage Reinsert it properly and reinstall drivers. If problem still remains contect your vendor for replacement.
surinder is offline
