25-04-2009, 05:51 PM
Ankit
Need Help 2 Build New Gamin Rig upto 40k
hi frnds pplz help me to build a new gamin rig upto 40k...
i jus need for gaming and i only need is a CPU dats all
should i go for -
Q9550 or Q8200 or AMD x4 940 or AMD X3 720
which mobo ...????
gpu sapphire HD4850 512mb
power supply...????
and how are INTEX cabinet....????
Posted again:
which graphic card is better ATI or nVIDIA
Posted again:
which graphic card is better ATI or nVIDIA???
Reason: Automerged Doublepost
25-04-2009, 08:59 PM
Re: Need Help 2 Build New Gamin Rig upto 40k
Simply go 4 Amd 4 gaming purpose...
Amd phenom 2 920 2.8 ghz @ 10.2k
Asus m3n 78 em @ 4.8k
Ram Corsair 2 gb 1066 @ 1.4k - 2*2gb
Psu Corsair vx 450 @ 3.9k
Gpu gts 250 512mb @ 9.5k, 1 gb @ 10.7k
Case go 4 zebronics antibiotic @ 2k,
Keyboard & mouse any bundle @ 0.6k
Moniter samsung 2233 @10.2k...
This is best config 4 gaming @ this budget....'
26-04-2009, 10:41 AM
Tech addict
I think his budget of 40K is for only for CPU so don't include LCD and where is HDD and DVD writer rest of the components you suggested are good.
26-04-2009, 03:11 PM
Ankit
thanx yaar.....I need 2 know one more thing....
later on if i want 2 go 4 ddr3 ram n mobo ....then again i have 2 buy a grapic card.... or dis one will work with it....
Posted again:
dis mobo support overclockin....????
n hw is HD4850.....????
26-04-2009, 03:24 PM
Ankit
which component is more important in playin heavy games....is it....GPU...????
26-04-2009, 04:35 PM
Tech addict
Posted again:
1 Not at all
2 yes
3 great one in its price bracket
Posted again:
All the components have there roll to assemble a good gaming rig one should not ignore importance of any of them rather think of a balanced blend of components in given budget.
26-04-2009, 06:01 PM
Ankit
hd4850 is better than gts 250...????
Posted again:
is there any other ....better motherboard than asus m3n78
Posted again:
Posted again:
is there any other ....better motherboard than asus m3n78..?????
26-04-2009, 10:03 PM
EXIT: DATA Junkyard
P2 720 2.8GHz B.E. @ 8.4k
Biostar TA790GXB A2+ @ 4.8k
Kingston 4GB DDR2 800MHz @ 1.9k
Samsung 2233SW FULL HD @10.1k
Seagate 7200.12 500GB @ 3.1k
22x DVD Writer @ 1.1k
CM Elite 334 @ 1.8k (w/o PSU)
Corsair VX450W @ 3.9k
MSI HD4850 1GB GDDR3 @ 9.7k
TOTAL = Rs. 44,800
27-04-2009, 02:19 PM
Ankit
m confused hav b/w AMD X3 720 AND AMD X4 940
Posted again:
which is better for future gaming. l
27-04-2009, 02:38 PM
Bond, Desi Bond!
there is no need for confusion. Go for 940!!!
27-04-2009, 02:45 PM
Ankit
does asus m3n 78 em support over clockin n is stable or is there any other option...????
27-04-2009, 03:45 PM
EXIT: DATA Junkyard
Go for this, when you play at FULL HD with this GPU, the CPU won't matter much, even the E8400 would give the same fps.
27-04-2009, 10:13 PM
Ya go 4 phenom 2 proccys the r far better than intels...'
28-04-2009, 10:26 AM
Ankit
compadict is sayin 2 go 4 x3 720....n desibond is sayin 2 go 4 x4 940....
nw which is a better proccy ...n is there any better mobo then asus m3n78 em...
help me guy's.....!!!!!!!
28-04-2009, 07:33 PM
Ankit
hw Is biostar 790fx with integrated 3300 graphic card with AMD X4 940
will it work with HD 4850 In crossfire...?????
28-04-2009, 07:36 PM
Ankit
m goin 2 place order at lynx .....on 30 april....so plz help me guy's ....to build a cool gamin comp
28-04-2009, 07:58 PM
EXIT: DATA Junkyard
then get X4 920.
Why? Becuz both X4 920 and X4 940 BE hav same OC ability. 920 does 3.76GHz, and 940 does 3.8GHz.
28-04-2009, 08:24 PM
Ankit
n wot abt mobo...????
28-04-2009, 08:45 PM
#19 (permalink)
Bond, Desi Bond!
Get the best 790FX mobo that you can get.
28-04-2009, 09:19 PM
#20 (permalink)
Ankit
Palit HD4850 Sonic Special Edition 512MB DDR-5 - HW IS THIS GRAPHIC CARD...????
29-04-2009, 09:57 AM
#21 (permalink)
EXIT: DATA Junkyard
^^It's a lower clocked HD4870 512MB.
And talking about VFM, this one's a WINNER.
29-04-2009, 10:14 AM
#22 (permalink)
Bond, Desi Bond!
it's better to wait a week as HD4770 will create another set of price drops from nvidia. I have a feeling that GTS250 might become lot more cheaper (maybe down to 8k)
29-04-2009, 11:58 AM
#23 (permalink)
Your worst nightmare
I seen 2 benchmarks of HD 4770.It even outperforms GTS 250 and HD 4850 in some games and 9800GT and HD 4830 in almost all the games.It should be priced under 7.5k as its MSRP is only 99$.Just wait for HD 4770.
29-04-2009, 04:25 PM
#24 (permalink)
Ankit
i'll buy my pc on 5th y as m goin 2 buy fm lynx....befre dat i also hav 2 send him a 25% of my pc ....so can't wait...in this case.....m thinkin 2 buy hd4850 but don't know which brand.....???????
29-04-2009, 05:00 PM
#25 (permalink)
Bond, Desi Bond!
I pick GTS250 or GTX 260 over HD4850. And HD4770 over HD4850 and GTS250
29-04-2009, 06:14 PM
#26 (permalink)
Ankit
Product name Quantity Cost, Rs : AMD Phenom II X4 940
Rs :12,100.00 Asus M3N78-EM
Rs :4,841.00 Corsir TWIN2X4096-8500C5 4GBkit
Rs :4,883.00 Corair CMPSU-550VX
Rs :5,565.00 Seagate 500Gb SATA 3.5"
Rs :3,045.00 Samsung SH-223 Serial ATA 22x
Rs :1,137.00 Asus GF GTS 250 HTD 512 MB DDR-III [HDMI]
Rs :9,164.00 Total:
Rs :40,735.00
WOT DO U THINK ABT DIS RIG....
this is my config for my new rig ....
I want 2 know dat CM ELITE 334 will be able 2 lower down the heat produced by this system....??????
my budget for cabinet is 4k....
29-04-2009, 06:18 PM
#27 (permalink)
Bond, Desi Bond!
There is a cabinet from Zebronics, called Rage which has huge 220mm side fan and tiny LCD display to monitor temperatures. Try it out
http://www.zebronics.net/popup.asp?f...20Cases&d=Rage
shouldn't be more than 2k in price.
29-04-2009, 06:20 PM
#28 (permalink)
Bond, Desi Bond!
#29 (permalink)
29-04-2009, 06:24 PM
#30 (permalink)
Ankit
hw is thermaltake strike mx
