Old 22-04-2009, 11:45 AM   #1 (permalink)
Tech.Masti's Avatar
Default Budget 25k & 30k
my two friends are going to purchase pc separately, one have 25k and another have 30k budget.....
whats your suggestion about their specification?? they need only INTEL
please suggest ... both budgets are including UPS
Tech.Masti is offline
Old 22-04-2009, 10:04 PM   #2 (permalink)
Tech addict
surinder's Avatar
Default Re: Budget 25k & 30k
what are the total components required means if displays and speakers also have to be included as well in given budgets And what for they will use those PCs for.........????????
surinder is offline
Old 22-04-2009, 10:11 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Plz don't give ONLY INTEL Sh!T
for 25k
X2 7750 B.E. @ 3.5k
Biostar 780G A2+ @ 3.2k
2*2=4GB DDR2 800MHz Kingston/Transcend RAM @ 1.9k
CM 334 Elite w/o PSU @ 1.8k
Cooler Master CM460W @ 2.6k
Seagate 7200.12 500GB SATA HDD @ 3.1k
UMAX Power Beats UPB 3200 2.1 @ 1.3k
Logitech kbd/mouse combo @ 0.8k
SONY 22x DVD Writer @ 1.2k
IF POSSIBLE - Palit 9600GT 512MB GDDR3 @ 5.4k
for 35k
Everything same, expect these:-
Core 2 Duo E7400 2.8GHz @ 5.8k
Gigabyte G31 @ 2.6k
About me:
http://about.me/preetam_nath
comp@ddict is offline
