Originally Posted by lethalweaponforever
Hi,
I'm facing a serious problem
I switched on my system one night and it started as always....then suddenly i got this screen saying that windows wasn't shut down properly last time and wanted to know how i want to start windows...
Safe Mode
Safe Mode with Network
Safe Mode with cmd
Last known good Config
Normally
whatever option i choose, about 3 seconds after choosing, my system RESTARTS!!!!! I DUNNO WHAT TO DO????!!!!!! THIS HAPPENS CONTINOUSLY
AM GONNA BE SO SCREWED IF SOMETHING GOES WRONG...
All i did before this happened was:
i took the LCD monitor connected to that PC out and connected a CRT to it coz i wanted to give the LCD for servicing...... HELP!!!!
Chance are only your boot.ini is corrupted so no need to reinstall.
Follow these as sorcerer said
Boot the system via windows disk.
During the setup, select the option R to go to recovery console.
When you get a dos-like screen
But instead of chkdsk use
fixboot command.If you want any help regarding this just enter
help to get info about these commands.Try
bootcfg after this to confirm that the OS entry is valid.
Posted again:
Also try
FIXMBR after
FIXBOOT,if master boot record is corrupted.
