Old 20-04-2009, 07:40 PM   #1 (permalink)
Default suggest a mobo for Core 2 Duo E8400
please suggest a good mobo for Core 2 Duo 3.0 GHz E8400
i was looking for some thing with firewire , e-sata port and igp.would be good if had hdmi also. my budget is 6k or below (i can stretch it to 7k if ther is none)
edit: ddr3 support would also be great if it comes in that budget
a55a55in is offline
Old 20-04-2009, 08:27 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: suggest a mobo for Core 2 Duo E8400
Gigabyte GA-EP43-DS3L @ 6.5k
OR
Biostar P43 TP43D2-A7 @ 4.5k
OR
MSI P45 NEO-F @ 5.8k
About me:
http://about.me/preetam_nath
comp@ddict is offline
