I tried to insert dvd writer from inside the cpu but it wont go because its front frame has more width than cpu frame...do i have to do it from front side???please help me
Re: Installing dvd writer in zebronics antibiotics
U should insert it from the front buddy...'
Just pull out the dvd casing frm inside the cabinet and then try to insert the dvd drive frm front and the tight it with the srews and then put back the dvd casing of the case...'
But I think u will have probs with the dvd casing.. Try to use the drive without it....'
