Old 15-04-2009, 08:25 PM   #1 (permalink)
Post Suggestion Required!!!!!
Hey Pals I want to configure a new comp.{gaming}{around18k}i want your help man.....
This is the configuration a friend of mine suggested....
Mobo: Asus Nvidia M2n68-AM
Procy: Athlon 64 X2 7750+ 2.9GHz
Ram: 2xOCZ 1GB DDR2 800MHZ
GFX: Palit 9800GT 512MB DDR3
so tell me i will go for this....
anything u can suggest under my budget.... please help i am confused and yeh i want to go with amd based cpu.....
Please Help....
Gotenstar is offline
Old 17-04-2009, 07:52 AM   #2 (permalink)
Tech addict
surinder's Avatar
Default Re: Suggestion Required!!!!!
Please Help....
Let us know first what are the components do you want to buy in this budget.
surinder is offline
