Old 13-04-2009, 07:03 AM   #1 (permalink)
ganeshravi's Avatar
Default CPU cooler
hi,
my stock cpu cooler has gone for a toss(processor: Intel C2D E8400).... am looking for a new one.... could anyone suggest me a good one.. budget max 2k. btw am from chennai... so i would preferably like to know the rates in chennai...
thanks in adv..
E8400 @ 3.6Ghz|cooler master Gemin II|MSI P45 Neo-F|corsair 2x1GB 800Mhz DDR2|corsair vx450w|WD 250GB|palit HD4850
ganeshravi is offline
Old 13-04-2009, 04:15 PM   #2 (permalink)
ganeshravi's Avatar
Default Re: CPU cooler
kindly help guys,,,,
Old 13-04-2009, 04:19 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
http://www.thermalright.com/new_a_pa...50aHVzaWFzdA==
http://www.ocztechnology.com/product...a_2_cpu_cooler
both around 2.2k
desiibond is offline
Old 13-04-2009, 05:23 PM   #4 (permalink)
The Sorcerer's Avatar
What's the stepping of your e8400 BTW??
The Sorcerer is offline
Old 13-04-2009, 06:41 PM   #5 (permalink)
ganeshravi's Avatar
my stepping is 6... out of curiosity, what is the relation between the stepping and the heatsink..???
Old 13-04-2009, 07:37 PM   #6 (permalink)
There are 2 stepping for e8400- E0 and m0. SLB9J s-specs are e0 and SLAPC are m0. Some of the manufactured batches are pretty stubborn to overclock properly. Although I dont understand what you meant by "gone for a toss". Is it overheating on load?
Old 13-04-2009, 08:10 PM   #7 (permalink)
ganeshravi's Avatar
ha ha... no no... gone for a toss in the sense i broke one of the locking levers while removing it... the lever wouldnt just release so i put some pressure to remove it out of the mounting holes, the lever gave way... n from where do i find the stepping...?? the stepping '6' was mentioned in cpuz v1.40... nothing of the sort e0 or m0 is mentioned... only a c0)revision) is present..
Old 13-04-2009, 08:36 PM   #8 (permalink)
Check the option which says revision exactly below stepping.
Old 14-04-2009, 01:02 AM   #9 (permalink)
Freshly Churned Chutny :)
Debu_013's Avatar
There are a few good offerings by COOLER MASTER.
HYPER TX2:http://www.coolermaster.com/products...cate=1&id=2535
HYPER 212:http://www.coolermaster.com/products...cate=1&id=3096
GeminII:http://www.coolermaster.com/products...bcate=1&id=140
All within 2.5k
Debu_013 is offline
Old 14-04-2009, 01:24 AM   #10 (permalink)
Debu_013's Avatar
All within 2.5k
Posted again:
HYPER TX2: http://www.coolermaster.com/products...cate=1&id=2535
HYPER 212: http://www.coolermaster.com/products...cate=1&id=3096
GeminII: http://www.coolermaster.com/products...bcate=1&id=140
All within 2.5k.
Debu_013 is offline
Old 14-04-2009, 06:42 AM   #11 (permalink)
ganeshravi's Avatar
the revision specified there is C0.
Old 14-04-2009, 09:39 AM   #12 (permalink)
Sunbeam core contact freezer. Attachment is a push pin type but I think they have a bolt on kit though I am not sure. Comes with a tuniq tx-2 thermal paste syringe. There are 2 ccf- the 92mm version is bit below 2k, and the other one is bit above 2k.
