Old 12-04-2009, 11:09 PM   #1 (permalink)
Smile Best deal for Invertors
Please suggest me a good inverter with great battery backup and stability between 10k- 12k.
Need futuristic and value for money product.
Thx
Rajanav
Rajanav is offline
Old 12-04-2009, 11:21 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: Best deal for Invertors
Su-Kam
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 13-04-2009, 11:40 AM   #3 (permalink)
I have not used Su-Kam myself but it seems to be a good brand. The length of backup time depends on battery capacity and the load rather than on the inverter. What kind of load are you thinking of using?
pimpom is offline
Old 13-04-2009, 11:55 AM   #4 (permalink)
dOm1naTOr's Avatar
their sine-i series are gud.
ive been using a 1.4KV model for last 4.5 yrs. no problems till now.
thinkin of adding 2 more tubular 120/180AH batteries in parallel to current ones.
G3: XPS M1530 |
FZ 16.
Old 13-04-2009, 02:45 PM   #5 (permalink)
Thumbs up Re: Best deal for Invertors
Thanks for everyone's suggestions...
Rajanav is offline
