Old 12-04-2009, 10:52 PM   #1 (permalink)
Default Motherbord+Proccy-Budget 10k
My friend needs a new motherbord and a proccy for 10k
Purpose - light gaming and usuall stuff. Motherboard should have a decent inbuilt gpu.
Or
Is 8600GT DDR3 + 6-7k Mobo-Proccy combo good enough ?
Suggestions please...
redmanc is offline
Old 12-04-2009, 11:30 PM   #2 (permalink)
Tech addict
surinder's Avatar
Default Re: Motherbord+Proccy-Budget 10k
Processor :- AMD ATHLON X2 7750 BE = 3.3K
M.board :- GIGABYTE GA-MA74GM-S2 = 3K
OR :- BIOSTER A740G M2+ =2.7K
GRAPHICS:- PALIT 9500GT 256MB DDR3 = 3.5K
OR :- PALIT HD 4670 SUPER 512MB DDR3 =4.5K
surinder is offline
Old 13-04-2009, 06:06 AM   #3 (permalink)
Tux Fan
shaunak's Avatar
[Onboard]
Procy: AMD Phenom X3 Phenom X3 8450 Tri-Core = 4670/-
Mobo: Asus M3A = 4950/-
[With a Card]
Mobo: Asus Nvidia M2n68-AM - 2250/-
Procy: AMD ATHLON X2 7750 Black Edition - 3300/-
[or Athlon 64 X2 7750+ 2.9GHz 3550/-]
GFX: Palit 9600GT 512MB DDR3- 5400/-
[If you can extend a bit Palit 9800GT 512MB DDR3 - 7075- ]
Since you said gaming, I would suggest you go with a better GFX card over the better Processor. The 8600GT is not too good for gaming.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 13-04-2009, 08:20 AM   #4 (permalink)
Tech addict
surinder's Avatar
Originally Posted by shaunak View Post
[Onboard]
[With a Card]
Since you said gaming, I would suggest you go with a better GFX card over the better Processor. The 8300 is not too good for gaming.
8300 where did you got it from
surinder is offline
Old 13-04-2009, 08:31 AM   #5 (permalink)
Tux Fan
shaunak's Avatar
Typograghical error :embarassed:
Cheers
Shaunak
shaunak is offline
Old 13-04-2009, 10:20 AM   #6 (permalink)
Tech addict
surinder's Avatar
Ya I understand it can happeeeeeeeeeeen oops! you see.
surinder is offline
