Old 08-04-2009, 08:31 PM   #1 (permalink)
Rockstar In Nothing
Smile VIP 500 watt Smps
Hello
I want to know the price for VIP 500 watt SMPS .
Please tell me the price of smps and tell me if i can go for any other smps .
no matter of Budget
My specification is
Pentium D 805
Intel D102GGC2 Mobo
2X1Gb ram 667 MHZ
XFX 8600 GT GDDR3 256MB Card
PixelView Pro 3 Card
2 Hard drives Hitachi 160 Gb + Seagate 40 Gb
1 DVD writer .
Please reply.
Intel Pentium D 2.66 Ghz
1Gb Ram running at 533 Mhz
Intel 102 motherboard
Hitachi 160 GB HDD,Segate 40 Gb Hdd
Lg DVD Writer & Lg cd writer
15" Color Moniter
ankurya1985 is offline
Old 08-04-2009, 09:10 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: VIP 500 watt Smps
Go for this:-
Powersafe Silver 400W @ Rs. 1,400
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 08-04-2009, 09:20 PM   #3 (permalink)
The Sorcerer's Avatar
It should cost between 1.8k-2k
The Sorcerer is offline
Old 08-04-2009, 09:44 PM   #4 (permalink)
dOm1naTOr's Avatar
if u dun have budget constraints, then go for Corsair VX 450. hell of a best one for 4k
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 08-04-2009, 10:52 PM   #5 (permalink)
Rockstar In Nothing
Smile Re: VIP 500 watt Smps
Originally Posted by comp@ddict View Post
Go for this:-
will 400 watt be enough????
as in future i am wishing to buy I7 processor
Which one the VIP or the Powersafe . And should it worth it.
I will consider that .
Thanks
15" Color Moniter
Old 09-04-2009, 09:01 AM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Thanks
None will be good for Core i7.
And I don't think you'll buy a Core i7 w/o a good graphics card.
About me:
Old 09-04-2009, 09:40 AM   #7 (permalink)
I am giving based on your current rig. If its i7 then you will need something much better. There's allready a psu guide around so you can refer to it directly.
Old 09-04-2009, 09:50 AM   #8 (permalink)
Old 09-04-2009, 12:41 PM   #9 (permalink)
Rockstar In Nothing
That will be my second upgrade for future . Firstly i will upgrade Processor and mobo then the graphics card.
i have searched a lot but not able to find a guide in the internet can you tell me where i can get that guide.
15" Color Moniter
Old 10-04-2009, 06:26 AM   #10 (permalink)
Tech addict
surinder's Avatar
for in depth knowledge on PSU
Basic guide for the right power supply
For your future upgrade go for Antec EA-650 just spend few minutes at
Which PSU should I buy ???....
surinder is offline
Old 10-04-2009, 10:37 AM   #11 (permalink)
It was on the digit forums- well actually its on chip, digit and indiabroadband forums but here you go:
Old 10-04-2009, 05:20 PM   #12 (permalink)
Rockstar In Nothing
Thanks .
yes thanks for the guide .
15" Color Moniter
- by Anorion
- by ax3
