Old 08-04-2009, 03:16 PM   #1 (permalink)
YEEEEEE!!11one1!one!!
NVIDIAGeek's Avatar
Thumbs down What is wrong with this PC!? Please help me...
Hi, I have the PC which is in my sig. The problem is, when I am playing GTA IV or any "heavy" games, the PC stucks. I have to restart manually. It's irritating me! And, when I am surfing the net with music in the background, BSOD comes up. I think this PC is Phuced up a big time. This and a problem with PoP. I don't know if it's the prob with the game or my Phuced up PC. It's also gets stuck. And I have legit copy. Please give me a solution other than reinstalling the OS, if any solution is there of course.
See you guize in March.
BATTLEFIELD 3 FOREVAH!
NVIDIAGeek is offline
Old 08-04-2009, 04:24 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: What is wrong with this PC!? Please help me...
Update GTA IV using the latest patch. Seeing that you have 4GB ram, should I assume you are using 64 bit OS? Also update ati drivers and install farcry 2 hotfix- YES it does work for other games. What on Earth do you even by phuced??
If this doesnt work out, then run orthos blend test for 4-5 hours and let me know if it restarts. If it restarts, shuts down, orthos gives any error- its a hardware issue.
The Sorcerer is offline
Old 08-04-2009, 06:07 PM   #3 (permalink)
NVIDIAGeek's Avatar
^Phuced means F@1$ed . OK, I'll try what you told. I am not using 64-bit OS, but 32-bit . It's not only "games" problem, but general problem. And what about Prince of Persia?? Please help me 'bout that game...
