Old 08-04-2009, 12:41 PM   #1 (permalink)
Dust in the Wind
Skud's Avatar
Default Help me buying a LCD TV
I want to buy a LCD TV and my budget is 30000/-. Please guide.
Skud is offline
Old 08-04-2009, 03:03 PM   #2 (permalink)
Default Re: Help me buying a LCD TV
well you can opt for LG 32" plasma which is around 26K. dont go for LCD in that price range as you will get sluggish performance and will repent on it. If you can downgrade size from 32" to 24" or 22" inches then you can get somewhat good TV.
amitabh_kaushal is offline
