Old 03-04-2009, 09:25 AM   #1 (permalink)
toofan's Avatar
Default DVD Drive not showing.
Friends,
Suddenly My Moserbaer LightScribe DVD Drive is not shown by Win XP from yesterday.
and its taking a long time at startup.
I have to manully select the Boot drive as hard disk.
Whats gone wrong.
My config.
Intel C2Duo E6750
4 Gb Ram Kingston DDR2 800 Mhz
8600 GT Palit super
Zebronics Lava cabinet with 400W PSU.
MSI P-35 Neo Motherboard.
thanks.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 03-04-2009, 10:17 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: DVD Drive not showing.
Is that IDE or sata? Certain updates of windows xp made pio/dma to conflict.
The Sorcerer is online now
Old 03-04-2009, 03:48 PM   #3 (permalink)
toofan's Avatar
Its connected via sata cable.
Check my work at:
toofan is offline
Old 03-04-2009, 03:55 PM   #4 (permalink)
Is the drive getting detected on bios? Make sure the settings are on DMA on bios as well as IDE/ATAPI controller on device manager.
Old 05-04-2009, 11:56 AM   #5 (permalink)
toofan's Avatar
some time its gets and sometime not. and its set to Auto DMA mode.
Check my work at:
toofan is offline
Old 07-04-2009, 04:12 PM   #6 (permalink)
If its getting detected sometimes then there's 4 possibilities:
Change the sata cable.
Try with a different sata power cable.
use a different sata connector on the mobo.
Your dvd drive is on the verge of dying.
Old 07-04-2009, 05:08 PM   #7 (permalink)
toofan's Avatar
I will change the Sata Port and also the cable if needed. And post the results.
Check my work at:
toofan is offline
Old 10-04-2009, 10:57 AM   #8 (permalink)
toofan's Avatar
Its working now after unplugging the cable and changing the port.
Thanks.
Check my work at:
toofan is offline
