Old 01-04-2009, 08:19 PM   #1 (permalink)
It's true Im not confused
confused!!'s Avatar
Question UPS not working
Well while I was playing Transformers yesterday, my SMPS and UPS suddenly stopped working...My SMPS actually fried and I replaced it. So my CPU is working fine now
Regarding my UPS, when I switch it on, the beep sound is audible and it does not respond to the power supply provided to it
Is it the fuse problem. Did it blow up when my SMPS went dead or the problem is deeper
After the game is over, the pawn and the king go into the same box
confused!! is offline
Old 01-04-2009, 08:46 PM   #2 (permalink)
serpent's Avatar
Default Re: UPS not working
main AC power may not be reaching the ups
and also check the power supply in you're house for any short circuit...
serpent is offline
Old 02-04-2009, 12:24 AM   #3 (permalink)
It is possible that the SMPS shorted and blew the fuse in the UPS. Is the fuse accessible from outside? Do you know how to check the fuse?
pimpom is offline
Old 02-04-2009, 12:50 AM   #4 (permalink)
Tech'ing life seriously!!
sude's Avatar
there must be a spike surge (sudden supply of high voltage) which had made ur smps fry and might be the fuse had gone off...
jus check it...
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 02-04-2009, 02:19 AM   #5 (permalink)
confused!!'s Avatar
Dont know but I will try it
Old 02-04-2009, 09:37 AM   #6 (permalink)
Call me D_J!
Disc_Junkie's Avatar
You are right. It happened to me also. It happens if your UPS outlet is loose and for which it cannot make appropriate connection. You will have to open the UPS and fix it.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
