Old 31-03-2009, 11:19 PM   #1 (permalink)
Default Best pc for <Rs.25000(only cpu)
hi,can you suggest me some processors,motherboard etc and looking for good 512mb graphic card
subbiah palani is offline
Old 01-04-2009, 08:27 AM   #2 (permalink)
Tech addict
surinder's Avatar
Default Re: Best pc for <Rs.25000(only cpu)
Tell your uses first Because different kind of applications perform best on different setups.
There is no thumb rule for a all rounder best system.
surinder is offline
