I'm planning to buy a graphics card from nehru place.
i talked to MASS COMPUTERS...he is offering NVIDIA 9400 card at a price of Rs.2200{512 mb} and Rs.3000{1 gb}
is it ok to buy a card of this model
plz give ur advice regarding NVIDIA only........
Your complete configuration please! Or else you might end up buying something which is incompatible with your system
Buying any hardware based on fanboism is pretty sILLY- especially in this day of age. Think of it this way- if you are getting something better for same amount of money- why not buy it?
OS-HP PAVILION- VISTA 32 BIT
PROCESSOR-INTEL CORE 2 DUO 4300@1.80 GHZ
INTEL GMA 950 GRAPHICS
HD-200 GB
RAM-3 GB
Plz tell if u need any more info
Posted again:
thanks SORCERER for rep.
HERE'S THE CONFIGURATION
HD-200 GB
RAM-3 GB
Reason: Automerged Doublepost
And what about the motherboard? If you cant find out on the product's manual, google and download cpu-z. The mainboard button will give you an idea. I want to know the wattage of the psu mentioned as well.
And the psu? Once you pop the hood your computer tower, You will see a sticker on the power supply (smps) which will have specifications being mentioned. Do mention what are the amps under +12v rail. Last thing you want is a blown up system only because the psu is under powered for the gfx card.
