Helo guys,am on a look out for a good set of gaming keyboard and mouse.
I want a mouse which is fully adjustable, and has a couple of custonizable buttons. I dont really care about dpi as 1000 dpi is good enough for me.
I was looking around then net and came up Saitek Cyborg
Fully-featured, adjustable, laser gaming mouse with 3200dpi for ultra high speed and accuracy.
Features:
Motorized length adjustment - customize to fit your hand size
Adjustable scroll detent force - set the sensitivity of your weapon selection
4-way d-pad and 3 extra buttons - more controls at your fingertips with a total of 10 buttons
Adjustable 400 - 3200 dpi laser - new anti-deceleration technology ensures reliable movement tracking, even at higher speeds
Mode switch - 3 modes vary mouse sensitivity and triple programmable commands (via Saitek Smart Technology software)
PTFE Hyper-glide feet - ensures smooth, low-friction movement
Specifications:
DPI: 400 to 3200 dpi (11 setting choices)
Image Processing: Anti-deceleration technology
Frame Rate: 40,000 fps
Acceleration: 10G (up to 98.1 meters/sec)
Max Speed: 45 inches per sec
USB Interface: Full speed
Data Format: 16 bit per axis
Report Rate: Up to 500 per sec
Standby/Sleep mode: Disabled
Where can i buy this? is it better than Razer mouse or Logitech G9 ?? Whats the price.
I am also looking for a good gaming keyboard. How is the Microsoft X6 keyboard? I would like a keyboard with LED backlight,and if possible USB 2.0 port and a headphone jock. And upto 5-10 customizable keys with MACRO editing feature.
