Originally Posted by crazypal24x7
@Disc_Junkie
yup there are time outs & the probable reason is broadcasting,any solution ?
the problem may be is with your TCP/IP limit........
In google, search "EvID4226Patch223d-en" and download it
Set the TCP value between 1 and 10 and check.....
You can also try TCP Optimezer and select the appropriate settings and check
Download it here
www.softpedia.com/progDownload/TCP-
Optimizer-Download-13752.html
And if this doesn't work, your service provider may me blocking the pings through your connection............
