Old 26-03-2009, 05:05 PM   #1 (permalink)
Always in Dreams...
Rishabh_sharma1990's Avatar
Question SATA or SATA 2. Any Difference??
Hey,
I have an AMD Athlon 64 Processor 3000+ 754 Pin.
And an ASUS K8V-MX Motherboard.
I want to purchase a Seagate 500 GB SATA hard disk. (My motherboard has SATA port.)
But i want to make sure if this hard-disk will support my system.
I read that hard-drives are now coming with SATA 2 Interface.
Will there be any problem because my Motherboard has SATA port, not SATA 2.
Currently I am using a 40 GB Seagate PATA Hard- Disk.
I play Bansuri! :)
Rishabh_sharma1990 is offline
Old 26-03-2009, 07:19 PM   #2 (permalink)
paroh's Avatar
Default Re: SATA or SATA 2. Any Difference??
sata 2 hard disk are backward compatible and there is no port difference between sata 1 and sata 2.
paroh is offline
