Old 26-03-2009, 07:23 AM   #1 (permalink)
toofan's Avatar
Default Max Temperature of E6750?
Friends,
E6750, Zebronics 400w PSU, GFX card Palit 8600GT Super 512mb ddr3., MSI P35 Neo Motherboard. (Till Now 2GB 633Mhz Ram) Ram 4 GB Kingston 800Mhz.
This is my config. Few days back I check the bios and found that the temperature of my Processor is around 80-90 degree centigrate.
Is it normal for that processor or is it too hot to use. Can it damage other parts also.
And how can I determine the true temperature of my Processer and Graphic Card.
Thanks.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 26-03-2009, 09:22 AM   #2 (permalink)
RMN
Default Re: Max Temperature of E6750?
on full load the max the proccy should go up is 70-80C
so definitely yours is OVERHEATING!!!!
your HS might not be placed properly or the is no thermal paste applied.....
try Coretemp,Speedfan,Realtemp to check the temps.
DELL SP2008WFP|Cooler Master Elite 330 Cabinet|MSI P45 NEO-F|Intel Q6600|Palit HD 4850 Sonic|VISTAx64|Cooler Master PCAR-600|Transcend 2GB 800M|Creative SB LIVE!Ext.|Logitech Combo EX-90
RMN is offline
Old 26-03-2009, 10:27 PM   #3 (permalink)
toofan's Avatar
I had bought a new crusoir heatsink for 140.00. will it work ok.? and what is the normal temperature for GPU.
Check my work at:
toofan is offline
Old 28-03-2009, 07:24 AM   #4 (permalink)
toofan's Avatar
Bump.
Check my work at:
toofan is offline
