Old 26-03-2009, 02:07 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Question LCD Monitor BenQ
hii guys , i will be purchasing a BenQ E220HD soon , and would want to know if the inbuilt speakers in the monitor .....would interfere with my already existing 2.1 creative speakers .....? , and i would also want to know the difference between E220HD and E220HDA ? , and i would also like to know ....if there are any monitors which are better than the above mentioned .......? , i will be using the monitor mainly for gaming and watching movies ....fullHD is a must in any monitor for my needs ...., and what is the difference between 5ms and 5ms(2ms gtg) , is it major difference ?
quasta123 is offline
Old 26-03-2009, 08:23 AM   #2 (permalink)
99.9% Idle
axxo's Avatar
Default Re: LCD Monitor BenQ
AFAIK we cannot use both the inbulit as well as external spkrs simultaneously. Only one at a time could be connected to sound card input unless there is multiple sound cards installed in the system. Also there would be no inteference bcoz of inbuilt spkrs that they are designed it to be that way.
Unban praka123
axxo is offline
Old 26-03-2009, 03:05 PM   #3 (permalink)
thanks a lot ! ! , that clears my speaker doubt ...but what about the rest ???? , would someone please advice me......., i would sincerely appreciate it ...
Old 26-03-2009, 03:54 PM   #4 (permalink)
search about samsung 2233sw
mkmkmk is offline
Old 26-03-2009, 04:50 PM   #5 (permalink)
Tux Fan
shaunak's Avatar
GTG is basically a marketing gimmick that measures response time for a grey to grey transition. Practically, its of no use. Just compare the Black to white response times.
Lesser is better. Any thing above 8ms is a no go.
If your Sound card OP is high enough you can use a standard signal splitter to use both speakers simultaneously.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 26-03-2009, 06:33 PM   #6 (permalink)
Wink Re: LCD Monitor BenQ
I will suggest u 4 samsung 2233 sw moniter as it has the highest resolution than others and it also looks good with a blue led power button.I am using it and blive me it rocks in full hd while playing games like far cry 2 and cod 4..so go 4 it without any doubt....its price is 10.2k +.
Posted again:
Posted again:
Arnab boss is offline
Old 26-03-2009, 10:04 PM   #7 (permalink)
but the samsung model dosent have HDMI , is it a major draw back ????
Old 26-03-2009, 11:13 PM   #8 (permalink)
damnbadman666
damngoodman999's Avatar
benq E2200HD is nice one , but beware of dead pixels
samsung 2233 is gr8 monitor , consider Dell 2209 WFP monitor cause its performance is gr8er than benq , but the resolution is 1680 X 1050 native
damngoodman999 is offline
Old 27-03-2009, 08:53 PM   #9 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
E2200 for Sheer FULL HD and the reviews are very positive towards this monitor.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 27-03-2009, 11:41 PM   #10 (permalink)
Tux Fan
shaunak's Avatar
I would continue to dissuade you from purchasing a samsung monitor. Especially if you do graphical designing work.
The color reproduction is just average and you will notice a slight "moire" type scrolling due to improper syncing.
Resolutions and looks aren't everything (in fact, count for nothing). It is performance that counts. Go for Dell, its a very good panel.
My personal experience with samsung has been disappointing.
Cheers
Shaunak
shaunak is offline
Old 28-03-2009, 06:44 AM   #11 (permalink)
mikael_schiffer's Avatar
Why is everyone so crazy about E2200HD
Why dont just get the T2200HD.
Its the same as E version, its just that it does not support HDMI.
And by the way, dont be crazy about HDMI ports. U can get lots oh]of DVI-to-HDMI convertors in the market.
HDMI is a big headache, u have to connect ur speakers to the MONITOR.
DVI is the best. Hassle free and awesome performing. C'mon graphic professionals use DVI connected monitors.So be pretty sure that u r getting the best visual quality a monitor can offer when u connect it via DVI
I find no good reason to buy E2200HD. For Rs2,000 less u can get the similar performing T2200HD sans the HDMI.
The reason why E2200HD is so acclaimed is because of the GREAT PRICING and DECENT PERFORMANCE. Reviewers tend to over look the fact the lower end version is ALSO great value to boot.Thats why the T version not famous
http://mike-messiah.blogspot.com/
mikael_schiffer is offline
Old 28-03-2009, 02:46 PM   #12 (permalink)
damnbadman666
^^^ u r rite DVI rocks
Old 28-03-2009, 03:07 PM   #13 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Hmm, very right there, HDMI makes a hassle instead of doing any good, and it costs approx. Rs. 2,700 more.
Man, go for the E2200 HD instead.
About me:
Old 28-03-2009, 06:04 PM   #14 (permalink)
Tux Fan
shaunak's Avatar
If a cost difference of 2K+ is involved, definately go for DVI.
It is sufficient to display HD content.
Cheers
Shaunak
shaunak is offline
Old 29-03-2009, 10:12 AM   #15 (permalink)
Tech addict
surinder's Avatar
Just correcting you T2200 HD
Yes surely one can save few bucks with T2200 HD I'm using it and it is giving me great performance.
Posted again:
Difference between E220HD and E220HDA
E2200 HD = DVI-SUB+DVI-D+HDMI+inbuilt speakers (pay extra 2.7k for HDMI with parecticly no use in computing)
E2200 HDA = DVI-SUB only+inbuilt speakers (no DVI-D there realy sucks)
T2200 HD = DVI-SUB+DVI-D (go with this one for 9k only nowadays)
Samsung 2233 SW at 10k or so is a good one as well.
ALl these models are full HD.
surinder is offline
Old 29-03-2009, 12:08 PM   #16 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Sorry, meant the T2200 HD itself.
About me:
Old 29-03-2009, 12:29 PM   #17 (permalink)
I like to FIFA
deadkiss 009's Avatar
Why no one is speaking of SAMSUNG t220
And there is another newcomer from AOC also ( model V22 ) with the older 2230 FM. The only drawback from AOC V22 is though it doesn't have DVI and sports with VGA and HDMI. But it has 1,00,00:1 dynamic contrast ratio and is very good for gaming.
deadkiss 009 is offline
Old 29-03-2009, 03:08 PM   #18 (permalink)
Tech addict
surinder's Avatar
Because these models don't support full HD display resolution and SAMSUNG t220 costs much more then BENQ T2200 HD which is full HD capable.
surinder is offline
Old 30-03-2009, 08:27 PM   #19 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
And we also shud take into account response time. For gaming, 5ms or below is recommended.
About me:
Old 05-05-2009, 01:28 PM   #20 (permalink)
Hi Guys,
Looks like many of you are using Benq T2200 HD. I am also thinking of buying the same monitor, but for me one major constraint will be the height of this monitor, while mounted on the the stand. I searched a lot on the net but could only find it's stand-alone dimensions, nowhere I could find fint it's height with the stand.
Please help me, post it's height. It's very imporatant for me. I want my monitor to fit my existing computer table, replacing it isn't an option
Thanks
Nitin
ntomer is offline
Old 06-05-2009, 02:31 PM   #21 (permalink)
Bump...
C'mon guys. Some replies please...
I measured my desk, it can accommodate a 44 cm tall monitor. Will a Benq T2200HD fit in it?
Thanks
Nitin
ntomer is offline
Old 06-05-2009, 02:32 PM   #22 (permalink)
Bump...
Thanks
Nitin
ntomer is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/111631-lcd-monitor-benq.html
benq e220hd - Яндекс: нашлось 102 ответа This thread Refback 22-01-2012 03:31 PM
