Old 26-03-2009, 12:02 AM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Plez suggest Mobo around 2000/-
I have AMD athlon 3000+ and want to buy a mobo as my old is not workin now, i have a budget of around 2000/- for de mobo and 1000/- for ram.
Please help
ankushkool is offline
Old 26-03-2009, 07:29 PM   #2 (permalink)
ankushkool's Avatar
Default Re: Plez suggest Mobo around 2000/-
plez help
Posted again:
anyone?
Old 26-03-2009, 11:56 PM   #3 (permalink)
ankushkool's Avatar
are there mobo available for AMD Athlon?
Posted again:
please someone help
Posted again:
please someone help
Old 27-03-2009, 09:48 AM   #4 (permalink)
blackperl's Avatar
http://www.theitwares.com/
blackperl is offline
Old 27-03-2009, 09:50 AM   #5 (permalink)
ankushkool's Avatar
how do i find mobo 4 AMD athlon on this site?
Old 27-03-2009, 09:53 AM   #6 (permalink)
blackperl's Avatar
there is a section for AMD motherboard ,there are many board with details
from there you can choose your mobo
Old 27-03-2009, 10:01 AM   #7 (permalink)
ankushkool's Avatar
will AMD athlon work with the Socket AM2 mobos?
Posted again:
what sud be the socket type for AMD Athlon?
Posted again:
i checked my processor, it uses socket 939... will it be compatible with AM2? is there any 939 mobo available?
Old 27-03-2009, 10:38 AM   #8 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
soket 939 processor is not compatible with AM2 mobo,
939 mobos are available,buy any asus one frm local market.
or the best option is to sell ur current processor for 1~1.5k so u will have a total budget of 4k add 1.5k to it then u can buy new amd dual core with 1gb ram
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 27-03-2009, 10:40 AM   #9 (permalink)
blackperl's Avatar
Old 30-03-2009, 12:23 AM   #10 (permalink)
ankushkool's Avatar
@blackperl : there are no 939 mobos
@zyberboy : where can i sell de processor?
Old 30-03-2009, 12:39 AM   #11 (permalink)
dOm1naTOr's Avatar
via chipset MSI boards for both older 939 and new Am2 comes in sub 2k cat.
A brand new Sempron Am2 costs some 1.2k and am MSI via board costs 1.6k.
2GB DDR2 667 costs 900/- for transcent/kingston or even 700 for brands like dynet. 800Mhz ones costs 1.1~1.2k for 2GB transcent.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
