Old 25-03-2009, 05:43 AM   #1 (permalink)
Revolution's Avatar
Question Big Screen With Low Resolution !!!
I need a big cheap VFM monitor(19" or 22") for my brother.
I don't need HD.
Please suggest me !
Revolution is offline
Old 25-03-2009, 09:09 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Big Screen With Low Resolution !!!
Dell 198WFP for 7k
desiibond is offline
Old 25-03-2009, 09:23 AM   #3 (permalink)
Revolution's Avatar
How much gonna cost for 22".
I can spend max 8K.
I heard that Acer and Asus LCDs with low resolution are cost less than Dell.
Is that true.....
Old 25-03-2009, 09:39 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^ yep. If you want top quality, go for Dell. I have 198WFP and it's just stunning. for 22", you may have to pay 10k or more.
also check this one: http://accessories.us.dell.com/sna/p...9&sku=320-7540
Dell 1909W Ultrasharp model.
Stunning design and 3yr warranty. VGA, DVI and USB ports.
Old 26-03-2009, 06:33 AM   #5 (permalink)
Revolution's Avatar
Who sells Dell LCD in Kolkata ?
Old 26-03-2009, 07:22 AM   #6 (permalink)
Dell or Samsung 19 inch
22 inch will cost you more than 8k..Around 10-11k
rocky_pratik is offline
Old 26-03-2009, 07:28 AM   #7 (permalink)
Tux Fan
shaunak's Avatar
I have had (and continue to have) an horrible experience with samsung LCDs. Go for Dell.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 26-03-2009, 08:18 AM   #8 (permalink)
99.9% Idle
axxo's Avatar
I just bought an Acer V193W 19" for 6.2K. Excellent picture clarity and sharpness also the contrast when compared to my existing 22" from viewsonic. Recommended.
Unban praka123
axxo is offline
Old 26-03-2009, 08:48 AM   #9 (permalink)
I am using Samsung Monitor from last 5 years...There ASS rocks.I have a very good exp with Samsung
Dell is also good.
Old 27-03-2009, 05:37 AM   #10 (permalink)
Revolution's Avatar
Anyway,who sells Dell and Acer monitors in Kolkata ?
Old 29-03-2009, 02:46 AM   #11 (permalink)
Gowt1ham
Gowt1ham's Avatar
dont go for cheap, they will be out within 3 years apart from ghosting and dead pixels.
If u are really tight on budget and want 22" go for used dell, samsung and benQ(be careful of some models).
Gowt1ham is offline
Old 29-03-2009, 08:23 PM   #12 (permalink)
icebags's Avatar
technocrats sells "some" dell monitors. i baught my dell 19" from HCL showroom though.
both at chandni chowk Xing .
icebags is offline
