Old 23-03-2009, 07:22 PM   #1 (permalink)
Default DVD drive weird problem - LITE ON 20A1P?
LITE ON 20A1P DVD drive writes and verifies DVD's Data successfully using NERO, but to vain when reinserted to access DVD, drive shows the DVD as Coaster, of course I have up to 20 DVD Coasters like this, all burnt in this same LITE ON 20A1P DVD drive, sometimes burns to certain percentage like 23%, 11%, 8% and throws out DVD giving "Write Error" message, and to mention here, I even tried using Lens Cleaner and the result is same.
Also, firmware recently updated, media used in burning Sony DVD-R, Moser baer DVD-R, way back the same brands media was burnt successfully.
DVD Drive was bought an year ago, even writes and detects CD's successfully without any problems.
Memory is offline
Old 24-03-2009, 05:58 PM   #2 (permalink)
Default Re: DVD drive weird problem - LITE ON 20A1P?
Oh! guys no one come across this type of problem, any suggestions if so.. like your DVD burner's lens would be the culprit.. or so on
Memory is offline
Old 24-03-2009, 07:19 PM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
Go for Lens Cleaner otherwise it's time to get it repaired.
- MrinTech :)
mrintech is offline
Old 24-03-2009, 07:26 PM   #4 (permalink)
TheSaint
NucleusKore's Avatar
Hi
I have that drive for three years now, and it is the WORST DVD writer I've ever seen. I face the same problem as you. Besides, my writer does not recognise blank dual layer DVDs even after the successful firmware upgrade.
If you want to burn DVDs on that drive it IS POSSIBLE. Before you click the Burn button in Nero or ANY DVD writing software manually ramp the writing speed down to 4x and enable data verification. This is how I'm managing with my writer, so far so good.
Do let me know if this works for you.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 24-03-2009, 11:34 PM   #5 (permalink)
Tech'ing life seriously!!
sude's Avatar
well pals... i am a user of the same dvd writer mentioned for 2years now....
no problems..
even i am an avid copier of data...
i think the lens is the culprit..
though i would suggest inform liteon too..
goto http://www.liteonit.com/global/index...pper&Itemid=75
or
http://www.liteonit.com/global/index...pper&Itemid=70
and send them a mail..
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 24-03-2009, 11:53 PM   #6 (permalink)
Ethan_Hunt's Avatar
Well mine died exactly after a year of it's usage & exactly the time when it's warranty ended. It stopped reading any & every media. Didn't bother too much to get it fixed & bought a Samsung drive. This Lite-on model was perhaps the nosiest drive ever.
V for Vendetta
Ethan_Hunt is offline
