Old 22-03-2009, 11:50 PM   #1 (permalink)
Default flickering lcd moniter and sound problem
tell me the solution of my flickring moniter and some noice in my creative 2.1 woofer.
atif.intezar is offline
Old 22-03-2009, 11:56 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: flickering lcd moniter and sound problem
How do people even expect solutions if they havent told anything much about the issue?? Issues are system specific and varies depending on circumstances. Next time when you post, mention the complete configuration including the psu and what kind of connection you are using for the screen- dvi or vga?
In the meanwhile:
Update drivers, check the connections, try using some other speaker/headphone to make sure if the issues is the onboard sound or the speakers.
The Sorcerer is online now
Old 23-03-2009, 10:09 AM   #3 (permalink)
if u r using MSI 945GCM7 board there might be sound flickering problem!!
chandal
Posted again:
chandal
Last edited by chandal_keta; 23-03-2009 at 10:10 AM. Reason: Automerged Doublepost
chandal_keta is offline
Old 23-03-2009, 10:43 AM   #4 (permalink)
Call me D_J!
Disc_Junkie's Avatar
There may be three problems---
If you are using a CRT monitor, then it may be due to lower refresh rate. Go to the Display properties - Settings - Advanced - Monitor. Check up increasing the refresh rate in the refresh rate drop down menu and keep the suitable one.
It may also happen if you keep your woofer near your monitor because of magnetic properties which can absorb colour from pixels.
It can also happen if you are using a resolution which your monitor barely support. Lowering the resolution may solve the problem.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
