Old 22-03-2009, 04:42 PM   #1 (permalink)
Default COoler master PSU ???
I need to buy a COOLER master 600 W PSU..
Can someone tell me the INR???
the vendor told me that its around 7800 rs.
I just wanted to confirm whether itsright or so....??
Meanwhile COoler master is the best among the PSU 's rite????
If not wat else???
My sys config : Quad core , Intel Classic seriesMB, 2GB ram,250GB SATA HD , XFX 9800 GTX card....
how much watts is actually required???? Should I go for 600 w??
And the vendor told me that there r three kinds of PSU's :: REAL POWER , Modular and smethin.....
wats the proce range of each...and which one shoud I go for??
please suggest me...tanx in advance
raja1234 is offline
Old 22-03-2009, 06:44 PM   #2 (permalink)
The Sorcerer's Avatar
Default Re: COoler master PSU ???
Coolermaster is a big no no- atleast the extreme series. I allready made a basic guide and put up on the forums:
Basic guide for the right power supply
The Sorcerer is online now
Old 22-03-2009, 11:16 PM   #3 (permalink)
Am here for u
Vensanga's Avatar
i get my coler master 600wats in around 3400 i think in Chandigarh...take a look in Lynx.com
Vensanga is offline
Old 23-03-2009, 06:23 AM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
@ raja1234 - Which CM 600W model you're talking about.
CM 600W extreme Power Plus Rs. 3.4K
CM 600W Silent Pro Rs. 7K
CM 620W Real Power Modular Rs. 6.7K - Get this one.
CM 650W Real Power Pro Rs. 6.5K
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 23-03-2009, 04:29 PM   #5 (permalink)
M$™ Certified Spammer
entrana's Avatar
cooler master is an awesome smps. but i had a problem a few months ago. nothing serious. i just had to open the rink and clean the fans using compressed air and a brush. it was making a sound like hitting a spoon on a plate, continously. the smps is good though.
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 23-03-2009, 04:57 PM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
true if you are ready to shell out 7k-8, prefer Corsair!!
desiibond is offline
